Running roughjoker68 04-10-2005, 12:54 AM I have a 1995 chevy s-10 pickup with a 4.3 V6 TBI. It's running rough, i was told it could be the catalytic converter causing it. I was just wondering if it could be the problem. Kinda runs like it's flooded. jackass#1 04-10-2005, 01:44 AM how long since a good tune up? check fuel pressure. cat cuold cause it to run poorly, but so can so many other things. do you have any warning lights displayed? joker68 04-10-2005, 06:31 AM Tune-up around 5 months ago, did not change out the distributor or rotor. one of the spark plugs I didn't change was in there tight didn't want to break it. toenailclippers 04-10-2005, 10:56 AM have a solution to changing that tight plug.....you have to break the old onein order to get it out......break offf the insulation abovethe base that way you can get a swivel socket in there and pull the old oneout. its much easier to get a new plug in that an old one out OverBoardProject 04-10-2005, 01:27 PM have a solution to changing that tight plug.....you have to break the old onein order to get it out......break offf the insulation abovethe base that way you can get a swivel socket in there and pull the old oneout. its much easier to get a new plug in that an old one out That's a good idea toenailclippers jackass#1 04-10-2005, 09:22 PM try that cap and rotor, old plug and see what you think. joker68 04-10-2005, 09:37 PM I just wanted to thank you all for your help. jackass#1 04-10-2005, 09:51 PM any changes in the truck? joker68 04-10-2005, 10:00 PM No changes yet. I work 16 shifts on the weekend, so I have to wait till monday. But I'll let you know. Candi-Tommy 04-12-2005, 11:53 AM I would say that it is your EGR valve. I had the same problem and didn't know WTF to think. I was told to change the EGR and it runs like a champ now. kenyonja2007 04-12-2005, 12:13 PM My 2.2 was running really rough and acting like it was really rich. I had 2 problems at one time though, one of my EGR vacuum lines was broken and the throttle position sensor was bad too. Do you have any error codes? Automotive Network, Inc., Copyright ©2012
