press brake ,brake light and abs comes onLRLac 04-09-2005, 08:20 PM What is problem when i press on brake ,the brake light and abs light comes on most of the time. It does not comes on when i am moving. way2old 04-10-2005, 07:13 PM Is the master cylinder low on fluid? LRLac 04-11-2005, 04:56 PM Is the master cylinder low on fluid? The fluid level is OK. No codes in computer way2old 04-11-2005, 07:43 PM Possibly the switch in master cylinder. The problem there is most places want to sell a master cylinder to get the switch. Unplug switch and see if that helps. If it does, see if you can find a switch. Good luck. LRLac 05-17-2005, 08:43 PM :confused: When I said there were no computer code. Are there two different places to pull the code . One for the brakes and one for the engine. Automotive Network, Inc., Copyright ©2012
