S-10, won't go in gearjtiderencel 04-09-2005, 12:47 PM S-10. '86' manual transmission truck will not go in gear after starting engine. Bleeded the slave cylinder, still won't go in gear. how do you check the master cylinder and the slave cylinder to see if it is by-passing fluid. no leak under tranny or on floor board. Ducaire 04-09-2005, 01:10 PM Sounds like you've got problems, mate. :( Sorry I can't help. dmbrisket 51 04-09-2005, 04:06 PM did it act up any b4 it went out or just die? xtrememeasures10 04-09-2005, 08:05 PM My 97 did that last year. No warning at all. It was my slave and master cylinder leaking. so there wasnt enough pressure. You probably wont have any fluids leaking for a couple days but then it will start leaking all over. I personally dont know much about trannys so i took it 2 aamco. well good luck 16th hippy 04-09-2005, 08:44 PM will it go into ANY gear, or just not first?. also, when running can you hear the clutch stop spinning when you depress the pedal, and hear it start spinning when you release the pedal? if you hear nothing at all like this, then chances are there is a clog in the line, or one of the two cylinders are bad, if not both. if it has fluid, and it's not leaking, then it has to be moving it somewhere, or not moving at all.. might also wanna check the line from master to slave to see if it got kinked somehow. hope this helps. toenailclippers 04-09-2005, 08:53 PM hate it for ya jtiderencel 04-09-2005, 11:47 PM won't go in any grear. I don't know if clutch is spinning. lines are stright and in good shape. when bleeding the slave unit it flows all down my arm. I blead the unit like you bleed your brakes. some one told me you are supposed to open the bleeder valve, and just let fluid flow out. close the valve when flowing good. ???? don't sound right. 16th hippy 04-10-2005, 08:54 AM hopefully doing this while keeping a good eye on the master to keep fluid in it. make sure u have someone helping, and make sure they have the pedal ALL the way to the floor when u open the screw. you could have air in the line still. would try doign it again....and keep going until u are sure there is no more air in the lines. lweford 04-10-2005, 09:42 PM I had this same problem. I replaced master cylinder & slave but didn't help. Finally pulled tranmission to replace clutch and found that the clutch fork, where it pivots, was almost wore in through. This wasn't allowing enough throw to fully ingage the clutch. Replaced clutch and fork and drives better than the day I bought it. deadBird 04-15-2005, 02:52 AM Simply bleeding it will temporarily fix your problem. If air got in there somehow, something else is obviously wrong. jtiderencel 04-15-2005, 06:10 PM bought a new slave unit, beld the shit, and fluid, out of it. got some gears, enough to get it to a shop. tell you what happens in the furture jt jtiderencel 04-18-2005, 05:36 PM shop said the clutch is out. S-10 belongs to the neighbor when he gets it fixed, i'll tell you how much it costs him. jt 16th hippy 04-18-2005, 10:08 PM willing to bet somewhere between $400 and $700 USD. jtiderencel 05-14-2005, 12:14 AM last report. cost 500+ to fix, they also fixed the exhaust leak. replaced clutch and all the goodies, ect. runs and shifts real good, smooth and easy. thanks for the advise talk to you guys the next time jt Automotive Network, Inc., Copyright ©2012
