Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Passat > '97+
Old 04-08-2005, 02:21 AM   #1
Ursul
Ursul Normal reputation
Unhappy Problems with the 1.8t :( need help
Hello! I need some help in identifying the problem with my car. I have a ’99 1.8t passat. As I turned on the engine the car began to tremble and the engine made more noise than usual. The “check engine” also flashes. I think it’s from the timing belt, but I hope I’m wrong. I just changed it last week at 120.000 km together with the tensioner and the water pump. Do u have any ideas what the problem might be? I was afraid to move the car...more smoke is coming out
Ursul is offline   Reply With Quote
Old 04-10-2005, 06:13 PM   #2
boschmann
boschmann Normal reputation
Re: Problems with the 1.8t :( need help
White or blue smoke?
boschmann is offline   Reply With Quote
Old 04-11-2005, 09:36 PM   #3
veedubmechanic
VDUBMAN
veedubmechanic's Avatar
veedubmechanic Normal reputation
Check for any vacuum line leaks, especially by the coolant resivour and the intake manifold.
veedubmechanic is offline   Reply With Quote
Old 04-11-2005, 11:41 PM   #4
Ursul
it was white smoke. I got P0301, misfire cyl1. I was told that it was the ignition coil, but the mechanic swapped the coils, and the problem was still in cyl 1. Now they say that there is a possibility that the valves have carbon (?) but they say that it also can be a valve hit by the piston if the timing belt wasn't tensioned correctly. If the timing belt wasn't correctly tensioned wouldn't i have to have problems in all cylinders? If the valves are carbonized the warranty covers the labour, but if it is the timing belt's fault, i would have to take it to the mechanic that changed it for me, because i have warranty from him for the job done on the timing belt. Who will pay then for the labour already done?
Old 04-13-2005, 12:15 AM   #5
boschmann
Check the compression on #1. Does the smoke/steam from the exhaust stop when the engine warms up?
Bookmarks
Google
Web AF
