1995 gl transmission fluid change
0311_lifer
04-07-2005, 11:34 PM
tomorrow im going to go buy some transmission fluid for this 95 taurus gl and i was wondering how much fluid should i get if im going to drop the pan and replace the gasket and filter and not a flush. how many quarts of the mercon atf should i buy ? the car has around 141,500 miles on it any recommendations on a specific brand ?
sfontain
04-08-2005, 07:46 AM
Oye. Tough question unless anyone has done it and measured it. I would err on the safe side and get maybe 8 to 10 qts. If you have leftovers you can save it till next time, or maybe you get another Mercon vehicle next, etc. And Mercon isn't terribly expensive stuff, at least compared to the Mercon V you would need if you had a newer Taurus. On brand: Valvoline seems to be consistently good for vehicle fluids; it may also be the most abundant in supply, and, indeed, the only Mercon V I've ever seen in a store is Valvoline.
way2old
04-08-2005, 09:09 PM
If you don't leave the pan off for very long, about 6 quarts will do. You need to run the vehicle for a little while before you check the level.
Willyum
04-09-2005, 10:32 AM
In case anyone cares, Wal-Mart carries Castrol Mercon V for about $3.00 a qt. Price was recently raised on all their oil products.
