not getting any oil return!!! help me out!geisi13 04-07-2005, 06:08 PM well i finally figured out why i was leaking oil from my turbo to my exhasut, for some reason the turbo is not returning the oil to the pan, its not my lines cause i took the turbo off and put oil into it and nothing is comming out, i dont know what would be blocking it off. anyone have an ideas? civickiller 04-07-2005, 08:33 PM how does the turbo spin ? any shaft play ? is it a used turbo ? and i remember your other post and i told you to make sure oil was coming out of the oil return geisi13 04-07-2005, 10:20 PM yea i took your adivise and checked, the turbo is brand new and there is no shaft play, im not sure which direction its spinning, id have to look tomorrow i dont have the turbp right here on hand. superbluecivicsi 04-09-2005, 04:14 AM oil retun is tapped above oil line in pan? you are sure of it? geisi13 04-09-2005, 04:30 PM oil return is tapped above oil line in the pan? i tapped the oil pan at the highest possible point on the oppisite side of the drain plug, and the turbo oil retun is highed than the spot i tapped the pan because it is gravity feed. the line isnt my problem, oil is comming out of the turbo itself. Automotive Network, Inc., Copyright ©2012
