Check engine light?
Google
Web AF
xodus917
04-02-2002, 11:41 AM
I really hate when a light pops up. and mine just did. I checked to tighten the gas cap, it could've been just that, but what else could it be?since it just popped up a few minutes ago i'll wait a while before i do anything. hopefully it will still be covered under warrenty if its somthin else
90CRXZCSi
04-02-2002, 11:52 AM
Check the ECU under the passenger side carpet to see how many times it's flashing. Then, you can tell me the code and i'll tell you the problem.;)
96LSIntegraRocket
04-02-2002, 02:30 PM
what do u mean ? like turn the car on and look under there and it will flash for so many times ? and pause between the number of flashes? my check engine light is on too but i think its because i took the air box cover was removed,.... id like to make sure,.......... thanks
00GSR
04-02-2002, 02:58 PM
Picture this. It's the weekend, you're out enjoying the open road, and WHAM, your "Check Engine" light rears it's ugly head. Ever wondered what was wrong with the engine? Not have enough money to take it to your mechanic and let him decipher the enigma? Well here's how you can learn what you're Electronic Control Unit (ECU) is trying to tell you.
Like the code machines of old, the ECU loves to talk in code. The only problem is deciphering it. Fortunately, you have this article to help you interpret it.
The '86-'91 Honda and '86-'93 Acura were equipped with a window on the ECU. On the other side of this window is an LED. This little LED would flash the code when the key was in the ON position. But unfortunately, the '92-'00 Honda and '94-'00 ECU was upgraded without an access window or LED. Replacing the LED though is a flashing check engine light. All that you need now is to pull the trouble codes, and you can do it with a jumper wire.
Locate the factory diagnostic plug next to the ECU for the Integra and Civic. There is a two-pin connector that contains a brown and black wire.
http://www.team-integra.net/sections/articles/images/connector1.jpg
Jump these two wires together and turn your key to the ON position.
http://www.team-integra.net/sections/articles/images/connector2.jpg
Here is where it gets tricky. Deciphering the code requires reading the light sequences. When the car is in the ON position, the check engine light emits two different flashes; a long extended flash means 10, and a rapid flash means 1. So, one long flash, another long flash, followed by 3 quick flash stands for...................23! Equipped with that information, here are the codes for the '92-'00 Honda and '94-'00 Acura.
0 ECU
1 Oxygen Content
3 Map Sensor
4 Crank Angle Sensor
5 Map Sensor
6 Coolent Temperature
7 Throttle Angle
8 TDC Position
9 No 1 Cylinder Position
10 Intake Air Temperature
12 Exhaust Gas Recirculation System
13 Atmosphere Pressure
14 Electronic Air Control
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor
20 Electronic Load Detector
21 VTEC Solenoid Valve (1.8L GSR)
22 VTEC Oil Pressure Switch (1.8L GSR)
23 Knock Sensor
30 TCM Signal A
31 TCM Signal B
41 O-2 Sensor Heater
43 Fuel Supply System
45 System Too Rich or Too Lean
48 Primary Heated O-2 Sensor
54 Crankshaft Speed Fluctuation Sensor
61 Primary O-2 Sensor Circuit
63 Secondary O-2 Sensor Circuit
67 Catalyst System
70 Automatic Transaxle
71-74 Random Misfire
80 Exhaust Gas Recirculation
86 Engine Coolant Temperature Circuit
90 Evaporative Emission Control System Leak Detected
91 Fuel Tank Pressure Circuit
92 Evaporative Emission Control System Insufficient
There you go :smoker2:
90CRXZCSi
04-02-2002, 03:09 PM
oh yea my bad. i was thinkin about my CRX. I havent had any problems with my integra yet and i just got it and didnt realize they were any different really. Thanks for clearing it up 00GSR.
xodus917
04-02-2002, 09:28 PM
its 9 long flashes
so its 90
i think it was the gas cap, I'll see if it will go away soon
90CRXZCSi
04-02-2002, 10:53 PM
Yea i think your right on the gas cap part. Just make sure everytime you tighten it that it gives quite a few clicks before your done tightening it. The light should go away. if your positive it's tight, reset the ECU and everytime you fill up make sure it's on tight and it shouldnt come back.;)
xodus917
04-02-2002, 11:03 PM
thanks for all your help
crow610
07-09-2004, 03:54 PM
I believe I got an error cold 9 (9 quick flashes) which indicates that something is wrong with No.1 Cylinder Position. Does anyone know what the No. 1 Cylinder Position is?
putz65
06-08-2005, 12:07 AM
I would like the codes for a 1992 integra
imasleep
12-02-2005, 03:46 PM
weeeee
superbluecivicsi
12-02-2005, 05:44 PM
this thread is 3 1/2 years old.
knorwj
12-02-2005, 06:23 PM
weeeee
what the f&#% is wrong with you? you dredge up an incredibly old thread, then as if that weren't bad enough you did it just to post some BS like that?:nono::nono::nono::nono::nono::nono::nono::no no::nono::nono:
DaSnowMan5
12-09-2005, 12:20 AM
Heck, I just bought the code reader from Kragen for $29.99. Wish I would have found this thread before I did that hahaha.. Found out when I read the book, WOW.. you dont need a tool to read it, just turn on the key and look through the window to see how many times it flashes, but at least now, for $30, I have a list of the trouble codes.. hahaha.
Google
Web AF
