1999 Plymouth Gv Speedmonitor/trans.DEBUCR 04-07-2005, 10:08 AM 1999 Plymouth Grand Voyager Speed Monitor Quit Working. At Same Time Trans. Will Not Shift Out Of Low Gear. I Drove It Around Block And Engine Service Soon Light Came On. What Is Going On With This? DEBUCR 04-07-2005, 10:31 AM 1999 Plymouth Grand Voyager Speed Monitor Quit Working. At Same Time Trans. Will Not Shift Out Of Low Gear. I Drove It Around Block And Engine Service Soon Light Came On. What Is Going On With This? STRANGE? rebuilder 04-07-2005, 07:17 PM 1999 Plymouth Grand Voyager Speed Monitor Quit Working. At Same Time Trans. Will Not Shift Out Of Low Gear. I Drove It Around Block And Engine Service Soon Light Came On. What Is Going On With This? you require an output speed sensor.you have two but this one is closest to thr driverside tire. DEBUCR 04-08-2005, 06:47 AM you require an output speed sensor.you have two but this one is closest to thr driverside tire. IS THIS A DO IT YOURSELF JOB OR DOES IT NEED TO GO TO THE SHOP? IF DO IT YOURSELF ANY TIPS ON PROCEEDURE? DEBUCR 04-09-2005, 08:35 PM IS THIS A DO IT YOURSELF JOB OR DOES IT NEED TO GO TO THE SHOP? IF DO IT YOURSELF ANY TIPS ON PROCEEDURE? I replaced the output speed sensor myself. It was a snap. I picked up a pictorial of trans. and new sensor from dealership. Parts department guy was very helpful. It took 10 min to replace. $25 compared to $168 in shop. Thanks to rebuilder for advice on what was wrong. debucr Automotive Network, Inc., Copyright ©2012
