Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 04-06-2005, 06:21 AM   #1
almxdupintegra
almxdupintegra Normal reputation
Purpose of a header flange...
I am about to buy a used header from a friend. IT does not have a header flange so he tells me I need to weld one on. What is the purpose of the flange and do I need to have a flange.
FRIENDS DON'T LET FRIENDS DRIVE STOCK
almxdupintegra is offline   Reply With Quote
Old 04-06-2005, 12:29 PM   #2
almxdupintegra
Re: Purpose of a header flange...
Sorry the flange that connects to the exhaust.
Old 04-06-2005, 12:51 PM   #3
pepsihatman
pepsihatman's Avatar
pepsihatman Normal reputation
Send a message via AIM to pepsihatman
I imagine you are talking about the part that bolts into the catalitic converter. Usually there are 2 bolts with springs down there that a flange meets up with. Without that flange, I'm guessing it won't hook up properly and you will have a mad exhaust leak. Might want to ask the other guys too, I may be wrong, I'm not too experienced yet.
~!~David~!~
1998 GSR, 86k miles, AEM CAI, DC 4-2-1 Ceramic Header.
pepsihatman is offline   Reply With Quote
Old 04-06-2005, 01:54 PM   #4
CivicSpoon
CivicSpoon's Avatar
CivicSpoon Normal reputation
Yeah the flange is what hooks up to the rest of your exhaust. Without it there's nothing to hook it up to, just the end of the header pipe (the round end of a pipe). So you need the flange to hook it up to another pipe.
CivicSpoon is offline   Reply With Quote
Old 04-06-2005, 03:05 PM   #5
knorwj
knorwj's Avatar
knorwj Normal reputation
Send a message via AIM to knorwj
the purpose of that flange and thick donut gasket and springs down there is so that when your engine moves due to heavy acceleration it doesn't break your exhaust etc. or if you happen to genlty tap something with the exhaust it doesn't snap any bolts on the header. The springs are there to hold it in place but to allow it to pivot slightly on that donut gasket.
So with out that flange the exhaust will have nothing to bolt to first of all and if you just weld it you lose that point of movement therefore putting yourself at risk for exhaust leaks in the future.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
knorwj is offline   Reply With Quote
Old 04-06-2005, 05:14 PM   #6
almxdupintegra
Thanks for that great explanation. Would a muffler shop be able to custom make that piece as described above.
Old 04-06-2005, 07:17 PM   #7
knorwj
knorwj's Avatar
Re: Re: Purpose of a header flange...
best way to find out is to go to one and ask. I'm guessing it would depend on the muffler shop.
Old:
New:
Newer:
Old 04-07-2005, 04:19 AM   #8
sameintheend01
sameintheend01's Avatar
sameintheend01 Normal reputation
Send a message via AIM to sameintheend01
i would ixnay buying that header.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
sameintheend01 is offline   Reply With Quote
Old 04-07-2005, 09:01 AM   #9
almxdupintegra
??ixnay??
Old 04-08-2005, 04:51 AM   #10
b20rex
b20rex Normal reputation
Send a message via AIM to b20rex
u can always go buy a flex pipe it does the same thing but unless u geting that header dirt cheap i wouldnt get it because if u weld it on u got to cut it off but if u do want it the easiest way is to use a flex pipe my car has one and i hav no trouble out of my exhaust
b20rex is offline   Reply With Quote
Old 04-08-2005, 11:31 AM   #11
almxdupintegra
Flexpipe?? How reliable is that?
Old 04-08-2005, 06:38 PM   #12
pepsihatman
ixnay means "nix" or to not buy. It's pig latin.
~!~David~!~
Bookmarks
Google
Web AF
