Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 04-04-2005, 05:43 PM   #1
dmbrisket 51
dmbrisket 51's Avatar
dmbrisket 51 Normal reputation
Send a message via AIM to dmbrisket 51
stupid just woundern question
what is vorec? I know our trucks can have a vortec and non vortec moter in them. Is it kind of like a computer controlled issue (like v tec in a honda) or am i way off?
dmbrisket 51 is offline   Reply With Quote
Old 04-04-2005, 07:57 PM   #2
blazer94
blazer94's Avatar
blazer94 Normal reputation
Re: stupid just woundern question
dm, I found this at http://www.s10extremist.org/tech_articles/vortec.htm
The Vortec name first appeared on 4.3L V-6 engines in 1986.These engines were the first to use a new "Vortex technology" designed to create a vortex (powerful swirl like a tornado) inside the combustion chamber. The Idea behind this is to create a more even and well mixed air/fuel charge that both generates more power and is more efficient. Over the years this Vortex technology has changed and improved to develop many new changes in the GM power train division. In today's world 'Vortec' Means power and here is where the confusion starts. There are literally thousands of cylinder heads that have been made with the vortex technology since 86 and many people refer to 87 and later small block heads as 'Vortec' heads. While this is a half truth the heads that GM sells under the Vortec name and the ones everybody is buzzing about did not exist until 1996. From the exhaust side of the head you can't tell a vortec from any other head. They look nearly identical to all other chevy heads. The ends also look more or less the same. All the accessory holes on the outer edges look just like any other 87 and newer center bolt head.
The intake bolt patter is different! It uses an 8 bolt attachment. This unique bolt pattern and the casting numbers are the quickest way to tell them apart from other heads. You also can tell by the casting mark on the end of the head since the vortec head has a 3 triangle or 'sawtooth' casting mark. They are available under 2 casting numbers 10239906 and 12558062. Both casting are good and performance wise they have no difference.
Good web site, and lots of info.
Trailblazer 2005.
2WD LS
Brand new, No Mods Yet!
blazer94 is offline   Reply With Quote
Old 04-04-2005, 08:21 PM   #3
dmbrisket 51
thanks
Old 04-05-2005, 09:19 AM   #4
herkyhawki
herkyhawki Normal reputation
Here's another good article about the evolution of the 4.3L
http://www.babcox.com/editorial/ar/ar40047.htm
herkyhawki is offline   Reply With Quote
Old 04-05-2005, 12:33 PM   #5
dmbrisket 51
both are good writeups, thanks guys
Bookmarks
Google
Web AF
