Last Friday I had a Dianostics done on my Taurus and here are the codes they found.brittce 04-04-2005, 11:40 AM 1. P0401 EGR Insufficient flow detected 2. P0402 EGR excessive flow detected Can anybody tell me what parts are need to take care of this problem? sfontain 04-04-2005, 12:06 PM 1. P0401 EGR Insufficient flow detected 2. P0402 EGR excessive flow detected Can anybody tell me what parts are need to take care of this problem? Would be useful to know the year/mileage of your car (though not really necessary), but it's apparent from the codes that you have a '96 or newer. You quite probably need a new DPFE sensor; only buy this from your Ford dealer; don't get an aftermarket part. Around $80-$90; the swap is fairly straightforward if you can do things like changing spark plugs. If you don't have a Haynes or Chilton book, I recommend purchasing one ($15) as it will walk you through this operation. brittce 04-04-2005, 12:32 PM 1997/145000 The Tech at midas told me that I would have to change some EGR system components because of the rich smell of my gas mixture. sfontain 04-04-2005, 01:42 PM 1997/145000 The Tech at midas told me that I would have to change some EGR system components because of the rich smell of my gas mixture. The DPFE sensor is an EGR component. Actually, I've heard some people call it the "EGR valve sensor." A bad EGR valve is a possibility, and at your mileage it wouldn't hurt to change both, but it is possible to test your EGR valve. But failing DPFE sensors are *remarkably* common on these cars, and they are a frequent cause of P0401. In any event, removal and cleaning of the valve isn't going to hurt, if it's something you'd like to try to tackle. Again, the Haynes book will help you in removing/reinstalling the parts; then, for cleaning advice, I would recommend you search online and in the forums at TaurusClub.com. brittce 04-04-2005, 02:26 PM Thanks I Was Trying To Figure Out What Was The Dpfe Sensor As I Saw That It Has Three Different Components To It, By The Way Which One Is Most Important. sfontain 04-04-2005, 03:12 PM Thanks I Was Trying To Figure Out What Was The Dpfe Sensor As I Saw That It Has Three Different Components To It, By The Way Which One Is Most Important. Not really sure what you're referring to. The DPFE sensor is one thing. brittce 04-04-2005, 03:30 PM The Haynes Guide is telling me that the DPFE EGR system consists of the EGR valve, the EGR vacuum solenoid,the back pressure sensor thats what the book says, I'm looking at it right now as I type this reply way2old 04-04-2005, 03:34 PM The DPFE is what they are referring to as the backpressure sensor. This is what tells the PCM what position the EGR is in. The vent solenoid releases vacuum to the valve to shut it off. KR1 04-06-2005, 10:45 AM 99 Taurus 24v DOHC.. I just changed my DPFE Sensor after a P0401 code.. Sensor is hard to get to on my engine... Paid $51 at Autozone.. brittce 04-06-2005, 01:59 PM I Just Change my DPFE sensor Yesterday and the Service Engine Soon light is gone Thank goodnes for DPFE sensor now I don't smell those rich gassy fumes anymore sfontain 04-06-2005, 02:20 PM I Just Change my DPFE sensor Yesterday and the Service Engine Soon light is gone Thank goodnes for DPFE sensor now I don't smell those rich gassy fumes anymore You're welcome. :D brittce 04-06-2005, 03:04 PM I appreciate all those who replyed to my thread thank you so very much and a special thanks to Sfontain you da man Automotive Network, Inc., Copyright ©2012
