a/c type 12 or 134atmbrrwofl 04-04-2005, 01:23 AM My a/c isnt blowing cold anymore and with summer coming, I was wondering what kind of freon it uses. 'teg is a 91 lss b18a and if its type 12, is it possible to switch to r134a easily? thanks in advance. whtteg 04-04-2005, 03:50 PM You have R12 and yes you can convert it to R134A you need to go to the local auto parts store and buy a conversion kit. It is rather simple to do. tmbrrwofl 04-05-2005, 03:44 AM You have R12 and yes you can convert it to R134A you need to go to the local auto parts store and buy a conversion kit. It is rather simple to do. Excellent, thnx whtteg. b20rex 04-08-2005, 04:19 AM actually u dont want to use that retro conversion cause r12 lines are not made r 134a refrigerant but if u really want to put 134a in there i would say go to a licensed a/c shop because if u use that retro crap u will need new seals some and to put 134a in r12 system ur suspose to vacum the r12 out and yes i know what im talkin about im certified to do a/c's and i have certification to buy r12 tran_nsx 04-12-2005, 08:37 PM My a/c isnt blowing cold anymore and with summer coming, I was wondering what kind of freon it uses. 'teg is a 91 lss b18a and if its type 12, is it possible to switch to r134a easily? thanks in advance. hey what whtteg wrote is correct. u can just go to walmart, they have the conversion kit from an r12 to r134a for about $34. but before u put the new stuff in, make sure u take it to a a/c specialist to remove all the r12 out. also before u put the conversion cap on, make sure u twist out the lil tab from the a/c nozzle. the directions didn't tell me to remove the cap so i lost about have the r134a that i just put in cause it wouldn't seal tight. tmbrrwofl 04-12-2005, 11:29 PM hey what whtteg wrote is correct. u can just go to walmart, they have the conversion kit from an r12 to r134a for about $34. but before u put the new stuff in, make sure u take it to a a/c specialist to remove all the r12 out. also before u put the conversion cap on, make sure u twist out the lil tab from the a/c nozzle. the directions didn't tell me to remove the cap so i lost about have the r134a that i just put in cause it wouldn't seal tight. excellent! thanks for the heads up on the a/c question guys! I'll go and get some this week end =D and i'll keep an eye out for that tab...tab in my a/c unit, right? tran_nsx 04-13-2005, 01:21 AM yes bro, the tab in ur a/c unit. to get a better visual, it looks just like the lil tab or middle prong that holds the pressure in which is sticking out of ur tire where u put air in. anyways, u have to remove that off first by twisting it off, then u can put the new conversion cap on. good luck. Automotive Network, Inc., Copyright ©2012
