bore to 2.0L or stick with 1.8L with turbo
aznbmxxxer
04-03-2005, 11:08 PM
i am using aebs sleeves, wiesco pistons and eagle h beam rods, i was wondering if i should bore it to a 2.0 or just leave it a 1.8. i want to boost about 15-18psi around 350hp. would the walls be too thin and be unsafe? whats the pros and cons of both?
civickiller
04-03-2005, 11:10 PM
the bigger the bore, the less psi it takes to get to your goal. why did you sleeve your motor for only 350whp ? stock sleeves can handle that
aznbmxxxer
04-03-2005, 11:44 PM
i sleeved it because i boosted it b4 and it cracked the sleeves, i plan on more power just waiting for the ecu and the fuel supply. how many hp should my set up handle safely and reliable? i want to use a little nitrous with the turbo too.
civickiller
04-03-2005, 11:49 PM
i wouldnt push more than 450whp on eagle rods. also you dont need nitrous
boosted331
04-04-2005, 04:26 PM
Jojo's old race car ran into the 9's and made 600+ WHP on eagles. Lots of people make over 500 WHP on eagles, both in Hondas and DSM's. I know Brad Tyson is running into the 7's at over 180 MPH in a 3200 pound car, turning 9000 RPM's in an 8 cylinder car running Eagle H-beam rods. 3200 pounds at 180 MPH is roughly 1700 horsepower, they can take power.
civickiller
04-04-2005, 05:30 PM
eagle themselves dont recommend anything about 450whp, just quoting what they said
Greenblurr93
04-04-2005, 06:02 PM
if you bore to 84mm (roughly 2L) then dont screw anything up because you wont have much left to safely re-bore it out.
turboEKhatch
04-05-2005, 02:57 PM
Click Me (http://www.boosted-hybrid.com/viewtopic.php?t=2032)
430 WHP @ 14 psi
605 WHP @ 27 psi
81.5mm, 9:1 compression, unported head, SC61. You don't need a big bore to make sick power. Eagle rods too :rolleyes:
londa hover
04-05-2005, 05:50 PM
exactly, i would deffinetly stay with stock bore, then when you crack your block you can bore it out 4more times
