Need troubleshooting ASAPBamaDodgenMX 04-03-2005, 09:28 PM Hey all, I've got a 1998 GMC Sierra 1500 V8 on my hands that just doesn't want to run. It stopped then wouldn't restart Saturday, which was traced to a burned-out in tank fuel pump. Pump replaced today, Sunday, and works fine. We now have fuel pressure, plenty of it, at both the pump, and the end of the fuel hose in the engine compartment. Seemingly though, there is no gas getting to the cylinders as the truck will start using starting fluid in the 'throttle body' yet not on its own. So, Help! Need to get it running to pick up kid from school, not to mention get to work on time. Thanks- :banghead: SpitAndDirt 04-04-2005, 07:00 PM Check cap and rotor for burned contact points. BamaDodgenMX 04-04-2005, 11:03 PM Will do, but thinking about it, wouldn't it not fire on starting fluid too if that was the prob.? SpitAndDirt 04-05-2005, 12:58 AM Depends on the mileage. Starting fluid is much more volitile than gasoline, so I would be careful using it. Have you tried cranking the engine with the plugs removed to remove excess gas? Try cranking again with dry plugs, and pull one out to see if its wet. Something doesn't sound right here, you need to go back and troubleshoot some more. BamaDodgenMX 04-05-2005, 03:00 PM I'll check the plugs, thanks. Ha, and I was hopin to troubleshoot on here, we all know that it's the drivers who know more about the vehicles, not so much the manuals. michaelmeck 04-07-2005, 05:38 AM also check your ignition module BamaDodgenMX 04-07-2005, 11:23 PM Well, problem solved. Turns out that while the new fuel pump worked, it just didn't work hard enough. The auto zone-supplied pump didn't supply quite enough pressure and a gm part did the trick. Silverado Brethern 04-08-2005, 05:18 PM Well glad you got it fixed. But...dude what is up with the dodge parafanalia? BamaDodgenMX 04-09-2005, 02:51 PM If you go to the link in my 'signature' you'll see my personal daly-driven truck. the truck i was posting about here happens to be my girlfriend's father's truck. so I'm a dodge guy.. but hey, if i have it my way ill be a dodge/hyundai guy here soon as i need a rice burner thats good on gas for college. Automotive Network, Inc., Copyright ©2012
