96 sierra signal switch/ multifucntion swithc
lorenjr
04-03-2005, 07:19 PM
I recently had problems with my signal switch. When i bought my truck a few months ago i noticed the brights didnt work so the other night i started looking into it. but i accidentaly broke some wire off and now i need a new one. Does any body know if a switch out of an s10 or a sonoma will fit in my 96 sierra? they look exactly the same. Ebay has some cheap for s10 but the sierra ones are a bit high for my pocket. any help would be greatly appreciated.
harley2024
04-03-2005, 07:41 PM
I had to replace the turn sig switch on my 94 Sierra because the cruse was not working. I was told the wires in the switch break very easy. And no I dont think another Mod. truck switch would work. They didnt have one in stock So I had to wait
Rocky
sherman69
04-05-2005, 10:15 AM
Hi,
When I need a gm part, I go to gmpartsdirect.com They have real good prices.
You select the catalog then find your part, then click it to your
cart/basket, Then go to checkout to see the price and shipping.
I find their prices to be 60-70 % of the dealer for real GM parts.
Bob B
TweakedGM
04-11-2005, 05:00 AM
did you have any wire left on the switch if so just put a longer wire in and solder the two. The tilt on the column streches the wire and pulles them apart. the muti-fuction switch is usaully ok for the cost of a switch try too solder them back to gather.
lorenjr
04-12-2005, 02:31 PM
no acutally the wire clips were solder right to the contact right on the back of the switch. i broke the contact right off when i was trying to pulle the wire off to fix the high and low beam wire. the wire that i had broke was for the wipers. i ended up using alot of liquid electric tape and a tooth pick to hold the wire till i can figure out what to do you buy a new switch.
