towing capacitybearcat329 04-03-2005, 07:13 PM need to know the towing capacity of a 97 expo, with the 5.4l triton, will be buying a trailer for camping. and would i need to add an aftermarket tranny cooler as well? tia Rick, Ore way2old 04-03-2005, 07:50 PM Need to know axle ratio and 2WD or 4WD. If you have owners manual, informaton is in it. Manual shows from 6700 pounds to 8000 pounds bearcat329 04-03-2005, 10:26 PM no owners manual, and it's 4x4 6800 - 8000 sounds close, any further info would be greatly appreciated way2old 04-04-2005, 08:07 AM If your wheel size is 16 inches and the rear end ratio is 3:31 6400 lb If your wheel size is 16 inches and the rear end ratio is 3:73 7900 lb If your wheel size is 17 inches and the rear end ratio is 3:73 7400 lb These are the recommended weights per Ford manual. Of course, you can probably fudge on the weights. :evillol: fitguy 04-10-2005, 11:11 PM There is some great info on tow ratings at www.trailerboats.com Automotive Network, Inc., Copyright ©2012
