how do I know where to set the tps sensor?
In_Style
03-31-2005, 10:59 PM
I replaced my TPS sensor, when I was installing it I noticed that it was able to be adjusted before tightened just by truning it and tightening it at a given spot. How do I know where to set it?
1999 Eclipse, 2.4l auto
kjewer1
03-31-2005, 11:01 PM
I would love to help, but I have no clue what car/motor this is on. Thanks.
In_Style
03-31-2005, 11:17 PM
wow do I feel dumb now, sorry about that. **Edited**
tfoti
03-31-2005, 11:21 PM
Might as well put that into your signature. Its under "User CP" towards the top.
nova1313
03-31-2005, 11:46 PM
The real question is did you get the memo? Because your TPS report doesn't have the new coverpage. Sorry I couldn't resist.
If you can get someone else to get you a reading off their sensor you can adjust it so that it puts out the same voltage at idle. Push the voltage higher usually means better response. Note that info isn't mitsu specific but thats how they work. You need to figure out the standard voltage (stock) or tune it yourself.
kjewer1
03-31-2005, 11:47 PM
Cant help on that motor, other than to say check the manual. There is generally a procedure involving using a multimeter and setting the TPS to a particular resistance. I prefer using a logger to set throttle closed TPS to 0%. Just being a couple percent off can prevent the throttle closed fuction from working and you wont get closed loop idle control. Any obd2 logger should work, most scan tools too, if you can borrow one of those. Otherwise, just do the meter trick in the manual.
beatdown944
04-01-2005, 12:26 AM
well put. from what I see (partially blind) this guy is the AutoForum guru.
