Oil Leak - Cam seal replacementclimber211 03-31-2005, 08:53 PM I have a oil leak on the passenger side, rear head. The stealership says it's a cam seal but it's not covered under warranty since I'm the second owner and the car has 85K in miles. Question I have, is this replacement something I can do? I'm pretty handy with a wrench, but never tore in to heads on a car. Has anyone replaced the seals themselve? Any mechanics have thoughts? I appreciate all thoughts and comments. boschmann 04-01-2005, 06:11 PM What engine? climber211 04-10-2005, 09:12 AM Boschmann, Might help if post the type of engine huh! Engine is V6, 30v. Talk to another dealer and price is right at 900.00. For RR of a valve gasket and seals, seems WAY to high. Thanks for any help. veedubmechanic 04-11-2005, 09:31 PM The cost here is arround 1100$. 1st owner covers to 100k. second to 50k I believe. marcuzz 11-27-2005, 01:45 AM veedubmechanic, '00 Passat, V6 30V -Took it in (non dealer) to replace water pump. They R&R the pump, timing belt, belt tensioner, coolant and an $85.00 vacuum hose. $890.00 total. Get it home and it's leaking oil big time. It's coming from up front. Would a new belt and tensioner cause the cam seals to leak or is it possible the belt was overtightened during installation? veedubmechanic 11-28-2005, 08:42 PM naw, cam seals are major prob on vw. the old style (grey) does not have an oil control ring (stupid design). The new style (black) does. normal labor is 8hrs replace 6 cam seals 2 cam plugs, 2 cam asj gaskets and v/c gaskets. along with some black vw gasket maker applies in "special" places. It does require special tools (can be aquired on e-bay for 160.00) Its not TOTALLY difficult, but if you have abilities to do a t-belt you can do cam seals. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
