Stage 1 or Stage 2?
Epower87
03-31-2005, 07:54 AM
Sup guys, im looking to get performnace cams for my car and i was wondering if i should get stage 1 or 2. The website says for stage 1 it works with stock valve springs. Daily driver. Idle to 6700 rpm and for stage 2 it says for agressive street use or nitrous. Idle 1000 to 7000+. i have an exhaust, intake, and header and there is a comp. chip on its way and i dont have nos. So what do u think will be best? and will they be worth spending 415$...Thanks
guitarXgeek
03-31-2005, 08:19 AM
First things first, what model DSM do you have? Turbo? N/A? It's very important that we know what you drive before we can help you. Also, WTF is stage 1 and stage 2? We need some more information about the cams, because stages don't really help much. What company are you planning on buying from?
Epower87
03-31-2005, 08:53 AM
i have an RS and its a non turbo..and the cams i want to get are from Crower...and on the website i want to get them from, it has 3 stages of cams the higher the stage the more work you should have done to ur car
Mitsubishi 420A Eclipse (non turbo)
64461 $ 417.95
Stage 1 - works with stock valve springs. Daily driver. Idle to 6700 rpm
64462-2 $ 417.95
Stage 2 - Agressive street use or nitrous. Idle 1000 to 7000+
64463-2 $ 417.95
Stage 3 - Full Race. Recommended for Drag Race use only. Kit # 84176 and ECU required. Idle 1500 - 7500+ rpm.
scottsee
03-31-2005, 09:43 AM
i guess its up to you. the more aggressive the grind the better upper end power. no matter what, you'll want to buy new lifters with a set of new cams.
Eclipse520
03-31-2005, 09:57 AM
This may sound like a dumb question but what would lifters be? and where might i get lifters? sorry for the dumb question haha.
scottsee
03-31-2005, 10:15 AM
http://www.slowboyracing.com/shop.php?sid=&cat=77
Epower87
03-31-2005, 01:13 PM
I dont want to sound annoying but i still dont really know what exactly lifters are and what exactly they do. I went to the site, and it said it was for turbo, does that matter? thanks in advance
JoeWagon
03-31-2005, 01:33 PM
Not to be mean but I would save the money for a turbo kit or a turbo car. How much power will you get with $400 cams? 10hp? If you were crafty or Jake, for $400 you could make yourself a turbo setup.
KevinE326
03-31-2005, 02:31 PM
sell everything and search autotrader.com for a cheap gst or gsx.
hellah fresh
03-31-2005, 11:42 PM
Hey i got $650 dollars saved up. Is that enough for a turbokit? Or should i save a little bit more to get a good setup...?
