Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 03-31-2005, 12:46 AM   #1
Pete in Post Falls
Pete in Post Falls Normal reputation
In Case You Run Into This......
While troubleshooting a problem where the right turn indicator light on the dash came on when I turned on the Parking/Clearance lights, I found the problem to be an open ground connection in the right front turn signal/clearance combination bulb assembly. It seems the current came to the clearance filament, but because it couldn't go to ground, went through the turn signal filament and back into the turn signal circuit and lit the turn signal indicator light.
Just sharing information.
Pete in Post Falls
Pete in Post Falls is offline   Reply With Quote
Old 03-31-2005, 12:34 PM   #2
broughy84
broughy84's Avatar
broughy84 Normal reputation
Re: In Case You Run Into This......
Interesting thing to know. I for one am glad you shared this little tid bit and that you got the vehicle fixed.
Matthew Brough
1998 Chevrolet Venture -- 104,000 miles
1988 Chevrolet Silverado -- 156,000 miles
1996 Chevrolet Cheyenne -- 107,000 miles
My 96 and 88 before the resto.
My 88 after the Restoration.
broughy84 is offline   Reply With Quote
Old 03-31-2005, 01:30 PM   #3
jveik
jveik Normal reputation
yeah i have that problem with my left turn indicator. when i have the lights turned on it is constantly on. also my blinkers in the front don't work only the parking light part works and they wont blink. so what do i do again? i have to change a bulb or what?
jveik is offline   Reply With Quote
Old 03-31-2005, 01:51 PM   #4
Pete in Post Falls
You can try the bulb, but if its the same as mine, replace the bulb socket. Mine cost me $11.00 at Napa. A twist, three wires and you are done. Make sure the black wire is connected before you do.
Are you saving that none of your front turn lights blink?
Pete in Post Falls
Old 03-31-2005, 09:50 PM   #5
jveik
well, i have a 73 chevy with the two blinkers on the front right above the bumper, and those only work with the parking lights and they dont blink when the blinker's on. its pretty wierd even more because the side marker light on the left front fender will blink when the signals clicked in. the right front fender bulb is just plain burnt out so i dunno about that one. but the only one that blinks is that left fender in the front and of course the rear blinkers
Old 03-31-2005, 11:46 PM   #6
Pete in Post Falls
Sorry I don't have any additional info on the 73.
Good luck.
Pete in Post Falls
Bookmarks
Google
Web AF
