Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 03-30-2005, 04:37 PM   #1
eddieeckenrode
eddieeckenrode Normal reputation
leaky water pump???
Recently I added some radiator fluid because I noticed it was low. I had to replace around 3 qts. . When I did this I noticed Fluid coming from somewhere around my water pump,(don't know exactly where do to it being so hard to really see the whole pump).So I monitored this for the last two days and as it got 3 qts. low again it stopped. Is this a bad pump or what? and why did it stop leaking when it ran low again?
eddieeckenrode is offline   Reply With Quote
Old 03-30-2005, 04:53 PM   #2
blazee
I'm gonna punch yo momma.
blazee's Avatar
blazee +50blazee +50
Re: leaky water pump???
The water pump has a weep hole that will leak to let you know that it is time to replace the pump.
Like this post? Hate it?
<----- Click the and tell me what you think.
blazee is offline   Reply With Quote
Old 03-30-2005, 04:58 PM   #3
EightyZ
EightyZ Normal reputation
yeah, i just replaced mine too, actually not that big of deal, air box, fan shoud, fan, and water pump, 4 bolts holdin it in. almost an easy fix, and the water pump being $47 from autozone was not too bad either!
EightyZ is offline   Reply With Quote
Old 03-30-2005, 05:07 PM   #4
eddieeckenrode
Re: Re: leaky water pump???
Yah I know about the weeping hole but do you have any idea why it stops after becoming klow again? Thanks for the help
Old 03-30-2005, 08:44 PM   #5
xtrememeasures10
xtrememeasures10 Normal reputation
Send a message via AIM to xtrememeasures10
Re: Re: Re: leaky water pump???
Lack of pressure. Mine started doing that when it was time 2 replace it. I got my water pump with a gasket for 25 bucks at Advance auto parts. took me about 30 minutes do replace. Make sure you have a drain pan and a couple gallons of coolant your gonna loose all your coolant. Infact I drained my radiator before i took of the water pump that will save you alot of drain time. good luck
xtrememeasures10 is offline   Reply With Quote
Bookmarks
Google
Web AF
