Skyline GTR octance minimumkoh 07-07-2001, 12:01 AM What is the minimum octance level for a Skyline GT-R? I heard from some that it's 100 (lucky japanese has better gas too). I want to find out before i consider getting one because I heard if you use 92 with performance mods it would mess up the engine. adamandsonja 07-07-2001, 08:30 AM my stock gtr 33 had problems with australian premium unleaded which is 95 octane. we have recently been able to get 98 octane easily. if u use 92 octane u will HAVE to use octane booster from a reputable manufacturer. adam R33 07-08-2001, 10:09 PM Hi Koh, the GTR, like all Japanese cars made for Japan, is optimised for the Japanese high octane fuel (100 ron -or is it 101?). Anything below 97 ron may result in problems. Especially when you have up-ped the boost from stock. The lower octane fuel does not burn like the 100 octane fuel - under extreme pressure and heat it explodes (detonate) rather than burn. A detonation for a few second is enough to destroy the engine. I use a cheap concoction with the 97 octane fuel for daily drives. A big intercooler also helps as it reduces the intake charge temperature thus reducing heat and providing more oxygen. Another option is to install a water injection system to further cool the intake charge and provide more oxygen. Of course another option would be Nitrous:devil: koh 07-10-2001, 11:30 AM So i can run NOS constantly and nothing bad would happen? And can a intake alone take care of the problems? koh 07-10-2001, 11:32 AM ANd don't new cars have this special programing chip that automatically changed tha engines configuration and stops detonation (teacher told me, he said 5 years old though, and I'm thinking about a 95) Moppie 07-10-2001, 11:41 AM All the imported GTRs here seem to run fine on 96. No you can't run NOS all the time, and since it rasies the Dynamic compression ratio you really need to run higher octane gas with it, so its not an answer to this problem. Pretty much all Japanese cars (and the rest of the world for that matter) made after 1990 have knock sensors. These detect the sound of knocking and retard the timeing, and/or richen the fuel mixture through the ECU to compensate. The result is that running on low Octane US gas you may not be making as much power as if the car was still in japan, (but who really cares). Of course people wouldnt be importing them if they didnt run on lower octane gas, so I wouldnt worry to much. If your are really concerned, then a bigger intercooller, (altough the GTR's is already pretty damn big) may help a little and lowering boost with a boost controler will definitly help. Water injection is an option, but it would be expensive to setup on a GTR, and you have to remember to keep filling the water tank, besides there's no proof that it will always cure engine knock. koh 07-10-2001, 03:16 PM thanks for all your responses, i'll go check out how much are those stuff. thanks alot, you don't know how much you helped adamandsonja 07-11-2001, 07:18 AM fact: the gtr's knock sensor only works up to a certain rpm - 3000 i think. fact: gtr is designed to run on 100 octane fuel, 92 will cause detonation. fact: i own a gtr that detonated (while standard ie. no engine mods or boost increase) when running on 95 octane aussie fuel. fact: detonation will cause serious engine damage. fact: retarding the timing is a bandaid remedy. if you cannot get at least 98 octane fuel put in some octane booster, it is not worth the risk of damaging a piston etc. moppie do you have a gtr? adam. R33 07-12-2001, 12:16 AM I agrre with Adam here. Not worth the risk of pre-ignition and detonation. I run my 33 on 97 ron and it's okay at 1.02 bar. But I have a huge GT i'cooler. For daily drive, I normally use my mechanic's concoction to boost the octane rating. On track, no option....always use the HKS booster. On NOS, I think a very mild dosage of NOS would help and could be used daily. I think NOS is ok if you use it to help the fuel burn more rather than using it in huge quantity to produce 50-100 or more horses...in that case it might hurt the bearing and even the pistons after some time. Water injection has been used quite extensively to prevent knocking. Quite expensive to install one in a GTR though. Big i'cooler will help if the fuel is not below 96 octane. Moppie 07-12-2001, 01:30 AM Originally posted by adamandsonja fact: the gtr's knock sensor only works up to a certain rpm - 3000 i think. fact: gtr is designed to run on 100 octane fuel, 92 will cause detonation. fact: i own a gtr that detonated (while standard ie. no engine mods or boost increase) when running on 95 octane aussie fuel. fact: detonation will cause serious engine damage. fact: retarding the timing is a bandaid remedy. if you cannot get at least 98 octane fuel put in some octane booster, it is not worth the risk of damaging a piston etc. moppie do you have a gtr? adam. Yes but your running on EXTREMLY low quality Ausie fuel, the same crap that forced Subaru to creat a special under powered version of the WRX for the Aussi market, after to many of the old model cars destroyed themself's. I find it hard to belive that the knock sensor would stop working above 3,000rpm, there would no point in having it, since most engine knock occurs at high engine RPM. I dont own a GTR, but there are certainly plenty of them running around on NZ roads, and most have been modded in some way, and run on 96 with out any trouble what so ever. These cars are also being imported into the states in limited numbers, and Iv yet to hear of any having trouble. A fuels Octane rateing is a poor indicater of how it will preform in the real world, the actual chemical composition has far more to do with how it will behave in a street engine. For example a leaded 96 octane fuel will resist knocking far better than an unleaded 96octane fuel. adamandsonja 07-12-2001, 08:48 AM quote from autospeed article on knocking "The ability of a fuel to resist knock is specified by the fuel's octane number. A fuel with a high octane number is more knock resistant". From personal experience loading up the engine also induces pinging, even at low rpm! the subarus that destroyed their engines were actually sti's, all were damaged on either racetracks or after periods of sustained high speed/ load driving ie. street racing. these cars didn't have their ecus altered, and were designed to run on japanese 100 ron fuel. the standard aussi wrx (155 - 160kw) was also supplied to other markets, japan likes to keep the "hot" stuff for themselves. i cannot comment on leaded fuel as it is totally unsuitable for a gtr and i've never used it. adam ps. maybe specifically ask some gtr owners if they have had pinging on anything less than 98 octane fuel - i'll bet yes. R35 07-12-2001, 09:24 PM FYI: MotoRex (the ONLY US importer for the Skylines) change the ECU as one of the many different things they do to make it US streat legal so there should be no problem running cars from them at the lowe octane. This is not necessarily true for a stock.. any car from outside the US. Since all cars that are legally imported into a country get modified to meet the standards of THAT country, most of the time it doesn't mean much when comparing a car in one country to another. Moppie 07-13-2001, 12:58 AM The Currtent model WRX as supplied to the Aussi Market is a detuned Version of what is sold in Japan, NZ and the UK. It runs lower boost, has a lower compresion ratio, and diffrent ECU mapping to cope with the lower quality Aussi fuel. (source, Motor, Autocar, NZ Driver). The STi is sold all over the world, and has been for some years. (it was the ADR that prevented it being sold in Aussie, thats why your getting the EVO VI while the rest of the world is getting the EVO VII) The WRXs that destroyed themselfs in aussie were engaged in all mannor of driving situations, and the problem was bad enough that Subaru took measure to prevent it happening, after the cars were repaired under warrenty they had a diffrent ECU fitter that reduced power. (why do you think the new model WRX is slower down the 1/4 in aussie, but faster than the previous model everywhere else.) When a the Octane rating of a fuel is measured it is done on a special test engine, that runs at very low RPM, and using a special head desgin that allows the compresion ratio to be adjusted while the engine is running. Its only a single cylinder engine, and does not provide anything like a real life driving simulation. The engine is run and the CR is increased untill knock is detected. From this the Octane rating is calcutated. However it fails to take into account things like changes in the Dynamic compresion ratio of an engine, and only serves as a rough guide to the fuels ablity to resist knock under a static compresion ratio. Hence when Lead was removed from NZ 96 octane fuel people with cars requiring a higher octane fuel reportred huge probelms with engine knock, (I was one). The lead in leaded fuel works very well at controling detonation, as it has a very high flash point and burns very slowly. However with out the lead in the fuel Tolulne was used to bring the octane rating up to 96, this resists knock well enough on a test engine, but in the real world is a very poor subsitute for lead. It has a lower flash point, and burns a lot faster. It is also very corrosive, and it took sometime before the Tolulene levels were reduced and other compounds were used. Australian fuel however still uses very high levels of tolulene, compined with huge distances accross which it is transported. Go ask a tanker driver about load loss over even a 100km trip, literaly the lighter compounds in the fuel, which are also the octane raisers will evaporate off very quickly, and so lower the fuels octane rating between when it arraived at the depot, and when it reachs the pumps. In New Zealand even heavily modified GTRs have no trouble running on 96 octane fuel. And we get a faster version of the WRX. R33 07-13-2001, 02:08 AM Moppie, instead of lead or tolulene, can Metahnol/Methane be mixed with 97 ron fuel to prevent detonation or pre-ignition? I think it's used for race cars with high compression.:confused: adamandsonja 07-13-2001, 02:13 AM do you understand that australia has recieved both the sti and the wrx - ie. the same car that great britan got as the impreza 2000 turbo ? Moppie 07-13-2001, 11:55 AM Originally posted by R33 Moppie, instead of lead or tolulene, can Metahnol/Methane be mixed with 97 ron fuel to prevent detonation or pre-ignition? I think it's used for race cars with high compression.:confused: Yes you can, and it will make a great diffrence to the fuels performance, unforunalty it will also do horrible things to your engine, as both are corrosive to Aluminum, and when mixed in high enough ratios to make a diffrence can be dangerous. (there is another reason for not using it, but I cant remember.) adamandsonja I never said the WRX and WRX STi wer'nt sold both new in Aussie, and as Japanese imports, However WRX's sold through dealers all use a diffrent ECU program and run less boost than versions in the Rest of the world, this gives them about 10-15 less hp, but avoids the problems associtaed with the low quality Aussie fuel. If you compare acceration times done by magazines the Aussie mags all show the Aussie WRX as being about 1sec off the pace compared to NZ or british models. adamandsonja 07-14-2001, 01:44 AM hmmm did i read this wrong ? quote "The STi is sold all over the world, and has been for some years. (it was the ADR that prevented it being sold in Aussie... " quote : "WRX's ... use a diffrent ECU program and run less boost than versions in the Rest of the world, this gives them about 10-15 less hp, but avoids the problems associtaed with the low quality Aussie fuel. If you compare acceration times done by magazines the Aussie mags all show the Aussie WRX as being about 1sec off the pace compared to NZ or british models. " ok lets do that - british CAR mag jan 1999 page 79 - wrx 215 hp, 0-62mph = 6.3 sec. , oz MOTOR mag march 2000 page 49 wrx 160kw (= 215hp), 0-100(=62mph) = 5.91sec would you like any other examples? i could also quote from TOP GEAR and WHEELS if you like, but i think that you should quit while i'm only slightly ahead! you tell me! adam R34GT-RVSpec 07-15-2001, 12:10 AM I live in the U.S. Does anyone know where I can get 98 octane at a pump? If not, where would i go about getting it anywhere? If I cant get it, what is the lowest octane i should use, and what octane booster should i use? Moppie 07-15-2001, 03:05 AM Originally posted by adamandsonja would you like any other examples? i could also quote from TOP GEAR and WHEELS if you like, but i think that you should quit while i'm only slightly ahead! you tell me! adam If you read the original wheels article they make a big deal about the new WRX being slower than the old one. Where everyone else who tested it in the rest of the world noted that it was a little faster. Ring up your local scuby dealer and ask them about it. I know the NZ dealers are quite happy to make a big deal about it. (I clearly phrased one sentance a little wrong. I ment that the STi had trouble meeting the ADR's, which ment it was late in reaching the Aussi market.) NIGHTMARE 07-15-2001, 03:18 PM I live in the US and own an R-32. I run on pump 93oct everyday on stock boost and dont have any problems. Now perhaps the fuel in the US is a bit better then whats in Aussie. However, when I turn up the boost I do run 110+oct just in case. FYI, Motorex doesnt change the ECU in the GTR's coming in the US. Moppie 07-16-2001, 07:27 AM Originally posted by NIGHTMARE I live in the US and own an R-32. I run on pump 93oct everyday on stock boost and dont have any problems. Now perhaps the fuel in the US is a bit better then whats in Aussie. However, when I turn up the boost I do run 110+oct just in case. FYI, Motorex doesnt change the ECU in the GTR's coming in the US. Hey man can I first say welcome to AF, (if someone hasnt already). Welcome to AF :D I was hoping someone who actualy owns an imported US Skyline might show up and clear this all up, it was getting a little OT. It sounds like either the knock sensor is able to cope, or US gas is of high enough Quality to prevent knocking to begin with. You must really enjoy driving it in America, do many ppl stop and ask questions? It would be like driving an F series truck over here in NZ. NIGHTMARE 07-16-2001, 10:42 AM Originally posted by Moppie Hey man can I first say welcome to AF, (if someone hasnt already). Welcome to AF :D I was hoping someone who actualy owns an imported US Skyline might show up and clear this all up, it was getting a little OT. It sounds like either the knock sensor is able to cope, or US gas is of high enough Quality to prevent knocking to begin with. You must really enjoy driving it in America, do many ppl stop and ask questions? It would be like driving an F series truck over here in NZ. Yeah I get pounded with questions all the time. It wasn't bad at first but sometimes you meet a group of obnoxious kids and it gets to you. But I guess it goes with the territory.:D Here is my R-32 if you havent seen it yet:) http://www.nissaninfiniticlub.com/registry/srm/005/skylinef0.jpg R35 07-16-2001, 02:32 PM Hey Nightmare, long time no post. Guess you've been busy driving:D BTW: Are you sure that MotoRex didn't change your ECU? Not to "knock" you are anything since you DO own a Skyline from them and I don't, but when I called them and asked about purchasing and what they do to make it US legal the told me that the ECU was one of the changes they do make. FYI: I was looking into getting a 99' R34. Agree with Moppie, nice to hear from someone who own's one in the US. :D koh 07-17-2001, 10:40 PM i emailed motorex about it and they replied with: In Japan Premium is 100 octane. However they use a different method to figure octane than the us . There 100 would be around a 95- 96 here in the US. The stock ECU's are not tuned to run on Premium so they run fine on 92 here in the states . But if you have a Japanes tuned ECU and try and run 92 you will have problems. But we have not had any problems with a US tuned ECU and performance parts. We just tuned an R33 - 505hp to the wheels @ 1.3 bar on US 92 octane pump gas. We have gone as high as 535 to the wheels on pump gas. NIGHTMARE 07-17-2001, 11:26 PM Originally posted by koh i emailed motorex about it and they replied with: In Japan Premium is 100 octane. However they use a different method to figure octane than the us . There 100 would be around a 95- 96 here in the US. The stock ECU's are not tuned to run on Premium so they run fine on 92 here in the states . But if you have a Japanes tuned ECU and try and run 92 you will have problems. But we have not had any problems with a US tuned ECU and performance parts. We just tuned an R33 - 505hp to the wheels @ 1.3 bar on US 92 octane pump gas. We have gone as high as 535 to the wheels on pump gas. There you have it fokes:) meggala 08-04-2001, 09:33 AM here in OZ you can get you ecu remapped for lower octane fuel so that it will run on aussie spec 95. The r32 is the only one that I know about that can do that. The japanese modded ecu's run crazy advance and run really rich most of the time anyway. they buy ecu's over the counter like you or I would a burger and fries. dyno time is very expensive over there. cheers meggala Gtr2.7L 08-04-2001, 11:46 AM That's the bomb for info. I've been trying to get somethin out of those guys for the longest. All I got from them is that I can't change my injectors/turbos/ECU. I've got an extra ROM chip running the OG fuel map...but I think I'll have to change my injectors back, and not rev on it with the turbos I have in it....unless Cali law won't allow it. What else did they change on your car? I've heard steel tubing in the doors for side impact and the window glass....any truth to that? by the way...the big thing in Japan now is the rolling Dyno's...Super Autobacs will do it for you for 5000 Yen (US 40 bucks). They have to estimate power at the crank, but who gives a rat's *ss about that anyway....it does give you straight R/AW HP numbers. Automotive Network, Inc., Copyright ©2012
