1990 jeep laredo wont even click !
juppy721
03-28-2005, 06:16 PM
help! 1990 jeep cheokee laredo 4x4 .4.0L. shut down while driving.
headlights,break lights,dome lights and key 'buzzer' WORK....
NOTHING ELSE !Turn key no sound .click,nothing.....battery good .lights bright . Maybe you can help THX !
Dale Aeppli
03-28-2005, 06:24 PM
WHEN YOU HAVE HEADLIGHTS ON TURN KEY, DO LIGHTS DIM OR GO OUT COMPLETELY DALE jeepman600@sbcglobal.net :smokin:
juppy721
03-29-2005, 06:39 AM
thx for responding. Turned lights on, turned key lights stay the same.
juppy721
03-29-2005, 10:03 AM
Horn doesnt work.....replaced horn relay didnt help
Could it be the starter solenoid?
Dale Aeppli
03-29-2005, 12:06 PM
Have you changed the starter at anytime. Try tapping on starter could possibly be a flat spot on starter armature. have you cleaned the battery cables and terminals. also check ground wires especally the braider ground wire drivers side from engine to fire wall. tug on ground cables may be bad connectors. hope this helps dale
jeepman600@sbcglobal.net :grinno:
juppy721
03-29-2005, 09:41 PM
Thx Dale! Trying what i can...Neighbor up the street says ..Ignition switch? WHAT do you think?
juppy721
03-29-2005, 09:44 PM
yes .tried your suggestions t y
juppy721
03-30-2005, 11:14 PM
DALE ! thx for the replies .YOU are the man ! Fixed it ! It was the green fusible link just located behind the battery ! Again thx for the replies,,,,,,,,,THIS is a great Forum to save $ and meet new peeps and learn a thing or two !!!!!!!!!!!
95xjsport
03-31-2005, 11:33 PM
ok mine is a 95 and does the same thing usually if I turn the hearer on when it is in the high position slide the slider from off, stalls and no power, lights work, no key buzzer, radio, hearer, no acc, nothing. let it set a few min and it comes alive again. It is not the Ign switch, I just bought that in november. 65.00 for a plastic switch thing. Holy Sh** the dealers rob you.
