Recall list for 2000 G20 (includes:Infiniti Vehicle Squeak and Rattle Materials)2000g20t 07-06-2001, 07:37 PM FYI: I'm gonna take this to the dealer this weekend and see what they say... http://www.alldata.com/TSB/27/00271003.html G-Forces 07-07-2001, 01:39 AM 99-032 JUN 99 ABS Sensor Caution When Using On-Car Brake Lathe They should amend this with "or Dyno." :D:D G-Forces 07-07-2001, 01:43 AM Umm, those aren't recalls. They are just services bulletins. Meaning that there may be some common things to look out for or different procedures to follow, like the flat towing bulletin or the on-car brake lathe. I had to take my G back to the dealer because of the washer nozle spray pattern needed to be adjusted. Nothing serious just small things. lmc18 07-09-2001, 09:26 AM How high do the nozzles spray up on your windshield? Mine only spray on the bottom third of the windshield when stationary or driving at low speeds. If I am going at a pretty good rate, then the water/fluid will slide up the windshield and get most of the dirt. I asked the dealer to adjust them and they said they are set as high as they can be. It's just annoying that I can't clean my windshield unless I am on the highway! I would like them to hit the middle of the windshiled if possible. ales 07-09-2001, 11:09 AM Mine spray wherever I want them to spray. It's really easy to configure them (on a P10 at least). There is this ball with an exit hole, and I just insert a needle in it ant turn it wherever I want. It doesn't want to move at first, though. Automotive Network, Inc., Copyright ©2012
