Top 10 Most Wanted Mods....silveradoking 03-27-2005, 12:10 AM Hey guys...I was wondering what are your top ten mods that you like the most....like a air intake or 4 headlight mod...? silveradoking 03-27-2005, 12:30 AM Oh, all right...if you insist... I'll be the first one.... 1. K&N Air Intake Polished 2. All forward lights (hi, low,drl, fog) on at once, when on hi mode. 3. Brake Light Mod 4. Federal Signal Emergency Blue/Red Strobes 5. Mag Lite Mod 6. Red Bowtie 7. Changed the tan Carpet to Black Carpet. 8. Cigarette Lighter Plug in Cargo Area 9. Electrical Outlets in Cargo Area 10. B&M Trans Cooler and Pan 11. 9005 Silverstars in both hi and low lights (who said we couldn't list 11 mods) I guess we could list are future planned mods as well.....Maybe I can start on some more bit serious stuff.... Future Mods... 1. B&M Shift Kit 2. Corvette Servo 3. Some Sort of Programmer or maybe Nelson Tune... 4. Dunno, what esle could I do....? Jake795 03-29-2005, 08:42 AM 1. Cam 2. nelson tune flashed on a newer PCM 3. 4.11 gears 4. suspension lift 5. 35" swampers 6. electric fans 7. Custom behind the seat box for subs 8. 4 headlight mod 9. suburban grill 10. aluminum bow tie Jake amac209 03-29-2005, 09:12 PM 1. remote start 2. lift 3. tires(35")&nice rims 4. gears 5. arb lockers frt& rear & onboard air 6. winch & bumper 7. satilite radio 8. light force lights 9. gps system 10. reprogram tranmission & engine yakk 03-31-2005, 11:17 AM Only one so far: Installed a harness to wire the iPod into the XM input. J-Ri 03-31-2005, 01:35 PM My required repairs: 1. Rebuild carburetor 2. New windshield 3. Replace ring and pinion gears in front differential After that, here's my top 12 wanted in order: 1. Desktop computer mounted behind the dash, will act as an MP3 player, DVD/CD player, and GPS unit. 15" LCD monitor in dash, DVD drive where radio was. 2. High quality webcam to mount on the dash, I'll make some offroad/storm chasing videos. 3. 12" subs. I'm thinking about making a weather tight box and mounting it in the bed under my toolbox. Any big reason not to do this? (I know it won't sound quite as good as behind the seat) It will be steel, and bolted to the bed (from the inside of the [dual padlocked/different keys] box) so nobody can walk off with it. 4. Good 6x9s for the dash, left, center, and right. My computer will have dolby 5.1 surround sound, so I may as well put a center channel in. I may have to switch to 4x8s(or whatever the next smaller size is from 6x9) if I can't squeeze 6x9s in [3" round speakers stock]) 5. 4 Amps (FL, FR; center; RL, RR; subs) 6. New doors with working windows and door locks (may rig up a 60,000 volt coil to the thumb button, set to stun when the doors are locked :evillol: 1-6 (except 3) will be installed at the same time (hopefully within the next 3 months), hardwood dashboard to cover all this. 7. 35"+ tires for offroading, no lift (don't want to get too tippy), but lots of fender trimming, and fender flares. 15" rims for those tires to go on. 8. LT235/85/16 tires for on road driving. Will go on my existing rims. 7 and 8 at the same time, whenever my current tires wear out. I have maybe 5,000 miles left till I hit 6/32" (the mud/snow wear limit). 9. Convert my A/C compressor to an air compressor (had to tear out my vent system to get the computer in anyway). I'll be able to drive to my offroading location on street tires (big tires are way too expensive to drive on concrete :eek7:) and use my impact to swap wheels/tires (8 lugs per wheel @118 ft-lbs is a lot by hand), and air up my group's tires. 10. 9,500 pound or bigger winch 11. 7 marker lights on top of the cab 12. New engine... if mine would ever decide to quit (or if I have a few thousand extra laying around sometime), no signs of needing it yet. Automotive Network, Inc., Copyright ©2012
