severe steering pullbill1842 03-26-2005, 02:22 PM while driving down the road in my 99 tahoe it will suddenly pull right or left, like if you were not holding the wheel you would go off the road, seems like it might be related to the four wheel drive system. any ideas? Ridenour 03-26-2005, 02:37 PM Bad allignment? Bad motor mounts causing unexpected torque steer? By the way, this is in the COMPLETELY WRONG section. v10_viper 03-26-2005, 07:40 PM Bad allignment? Bad motor mounts causing unexpected torque steer? By the way, this is in the COMPLETELY WRONG section. Yeah...def should be in the Chevy Forum. Don't get me wrong but I'm pretty sure torque steer is on front wheel drive vehicles, thus not effecting this. I know the Silverado's had a problem with their electric steering but I think that was later years, not yours. Give a few more details. Does it do it all the time, or just randomly? Have you done anything to the truck, prob not too effective but is the pressure in both front tires the same? Be a little more specific and someone will surely be able to help. tman 03-26-2005, 07:42 PM Moved from COT>Chev Tahoe 99 tahoe 03-27-2005, 12:56 AM while driving down the road in my 99 tahoe it will suddenly pull right or left, like if you were not holding the wheel you would go off the road, seems like it might be related to the four wheel drive system. any ideas? I had a similair problem, my control arm had to be removed on one side and reinstalled and then fully alighned. Also the 99 tahoe has some electronic stearing box which maybe your issue because mine was only pulling to one side not both. hope this helps localyokel 03-27-2005, 01:30 AM Hi,could be that one of your cam bolts on the upper control arm came loose.(Happens all the time)Ussually will clunk when bakes are applied.Must be realigned! skisteeep 05-12-2005, 05:35 PM Rotate your tires. It might feel worse for awhile after that but after a few miles it will get better. Then get an alignment. jrl snowed500 05-12-2005, 07:25 PM Check out this thread, sounds like your EVO sensor for sure...Check out my post, if you go to a mechanic they'll charge you $150 plus... http://www.automotiveforums.com/vbulletin/showthread.php?t=317059 bsamole 12-03-2006, 01:25 PM The Steering sensor is also available from NAPA. Part Number 31025 Cost $22.88 on 11/20/06 in Sparks, Nevada List $59.94. It is sold under the "HELP!" lable. Thanks for everyones help. I'd never figured out the hard pull on the steering was caused by this sensor. It is located under the dash on the steering shaft held in place by one 15mm bold. maxwedge 12-03-2006, 04:02 PM Welcome to AF, try to look at the dates as you post on threads, this is a year and one half old, dead now. Automotive Network, Inc., Copyright ©2012
