Need some help with a ZC problem!91REXSI 03-29-2002, 07:18 PM Hi all! I have a problem that I hope someone can help me with. I swapped a ZC DOHC motor into my 91 CRX si yesterday. When everything was finished, I tried to start the motor. It will turn over, but wont start. I checked, and I have fuel, but no spark. I have voltage at the connection at the distributor, am pretty confident my wiring on the distributor is correct. I spliced in the integra connector, matched up wire color codes, and sent the two blue wires to the crank sensor. I am at a total loss right now. Any help? Thanks much for your time!! mellowboy 03-29-2002, 11:31 PM Originally posted by 91REXSI Hi all! I have a problem that I hope someone can help me with. I swapped a ZC DOHC motor into my 91 CRX si yesterday. When everything was finished, I tried to start the motor. It will turn over, but wont start. I checked, and I have fuel, but no spark. I have voltage at the connection at the distributor, am pretty confident my wiring on the distributor is correct. I spliced in the integra connector, matched up wire color codes, and sent the two blue wires to the crank sensor. I am at a total loss right now. Any help? Thanks much for your time!! Did you check the battery? Or it could be your starter that went bad? velocitySiR 03-30-2002, 01:53 PM can you hear the starter winding???? because when we did my ZC in my old rex we just threw everything back in really quick and forgot the ground on the starter and that fucked everything up. Automotive Network, Inc., Copyright ©2012
