Engine sputteringwhoopimus 03-23-2005, 11:06 PM i have a 96 stratus 2.4L. When i start the car, it will sput while reaching idle rpm. it sputters rarely at idle, but when i floor it, the engine will sputter horribly, we have changed spark plugs, wires, fuel filter, everything and we have no clue what it is, thanks for the help. MrRoscoePC 03-24-2005, 10:01 PM Perhaps the EGR valve or bad EGR transducer. Check the Black round EGR (attached to the valve with vacuum line) transducers bottom for burning/melting or signs of water in it. whoopimus 04-08-2005, 04:30 PM i tested out the egr valve and it works 100%, ive looked at other websites and found the same problem, but no answer, must be a mystery :O MrRoscoePC 04-23-2005, 10:59 PM Still sounds like secondary ignition breakdown, does the coil pack terminals have corrosion on the tips? Bad coil pack?? Automotive Network, Inc., Copyright ©2012
