Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 03-23-2005, 04:17 PM   #1
nickwcr
nickwcr Normal reputation
car wash/water coming in under glove box
97 Jetta GLS
So this is a new thing - I take my car through the car wash and about half way through the wash I start noticing that water is coming in from under/behind the glove box. And its not just a little but enough to fill my passenger side floor. Is there anything I can do to prevent this?
nickwcr is offline   Reply With Quote
Old 03-24-2005, 04:30 PM   #2
boschmann
boschmann Normal reputation
Re: car wash/water coming in under glove box
You can remove plastic the air plenum cover on the right side of the car under the hood by the wipers. You only need to remove the three of four plastic screws & the rubber strip so the panel will come out. You probably have alot of debris clogging the drain under there.
boschmann is offline   Reply With Quote
Old 04-18-2005, 09:01 AM   #3
sio675
sio675 Normal reputation
Water...
..do you have a sunroof? If so check the drains in there as well..pour water from a gallon jug slowly in the area around the seal. If you see water in coming into the car you'll have to have the lines replaced.
sio675 is offline   Reply With Quote
Bookmarks
Google
Web AF
