4L60E Trannymotormax 03-23-2005, 12:12 AM For the transmission guru's out there, What is the difference on this GM tranny between 2wd and 4x4 with the transfer case hook up? Can you just remove the tail housing and bolt the transfer case to it? Does it require a different output shaft? Thanks trannyman52 03-30-2005, 12:25 AM requires a 4x4 output shaft,,,,,other than that ,,,nothing,,,,,problem being,,,the shaft is the first piece you put in the bottom of the case!!!! motormax 03-30-2005, 10:48 PM requires a 4x4 output shaft,,,,,other than that ,,,nothing,,,,,problem being,,,the shaft is the first piece you put in the bottom of the case!!!! Thanks, After I started this thread I saw a listing on Ebay for a 4x4 output shaft, I didn't know it's at the bottom of the barrel. Looks like I learn auto trans repair. Automotive Network, Inc., Copyright ©2012
