car idles to high need help
demon_joker
03-22-2005, 04:59 PM
i have an 89 240sx with an sr20det redtop in it i was driving it yesturday everything was fine but today when i started the car it was idleing at 3500 rpms when i put it in gear and drive it it returns to normal rpm but as soon as i put in the clutch to change gears to rpms jump again it only jumps when the clutch is in or the car is in neutral please help
whtteg
03-22-2005, 05:16 PM
Did it still do it after it got up to operating temp?
demon_joker
03-22-2005, 05:18 PM
yea when i start the car now it jumps to 3500 im not sure whats going on but once its in gear it drops to normal it only does it when its in neutral or when i put the clutch in to shift gears
Manji_240sx
03-22-2005, 05:27 PM
That happens to me sometimes but it has never happened to were it jumps to that high of an rpm level. maybe an maf problem or fuel delivery._what kind of fuel pump do you have?
demon_joker
03-22-2005, 05:33 PM
walbro 255
dontpurgethelines
03-23-2005, 11:50 AM
probally the injectors, check them out and see if they even look out of the ordinary. if thats not it then check your entire fuel delivery system becuse it sounds like one of the cylinders probally is gettin to much fuel
R.W.240
03-23-2005, 12:09 PM
Too much fuel would bog the engine not rev it to 3.5
Are you forcing the RPM down once in gear or does it do it with the clutch in too?
sounds like you've got a wiring problem. I dunno if the IAV would be able to get the RPM that high though.
Adjust your Throttle... it could be something gay like that
EDIT: Finished (gay teacher)
AWDSR20
03-23-2005, 01:53 PM
adjust the throttle cable...
mynismo
03-24-2005, 12:45 PM
engines always rev high when cold.
if it stabilizes when it warms up, this is normal. if not it could be your water temp sensor or tps.
R.W.240
03-24-2005, 01:11 PM
Yeah But 3.5?
mine does 1500 Cold and 800-1100 (depending on how the IAV is feeling I guess)
logik23
03-24-2005, 01:23 PM
I'd also say TPS, it might be thinking the gas pedal is halfway down even when you don't have your foot on it. Or something along the throttle cable.
