Screeching Noise on my new (but old) 318iDafordster 03-22-2005, 07:52 AM Hi, complete newbie here so please excuse if I asking something stupid. I just bought a 318i yr 92 and it makes a horrible screeching noise normally when I pull away and normally when the car is cold. Someone told me it id the power steering belt as it also makes the noise when I have the wheels turned to the maximum. I looked under the bonet and there are three belts, I don't know which one makes the noise or how to fix it - any ideas? Other problems include: 1) Electric Passenger Window doesn't move up and down properly. 2) Mileage display (digital) doesn't light properly so I can see the total mileage but not the trip mileage. 3) Water drips in when I have the driver sidfe window open. 4) Air con doesn't seem to work. Hope you can help with some or all of my issues - apart from those itr is soooo nice to drive!! Cheers, Dan. kenna325is 03-23-2005, 06:47 PM Might want to check your power steering fluid first. It's a lil cannister looking thing with a screw on dipstick. It takes ATF fluid, and might say ATF on the cap. Skycity_BMW 03-24-2005, 10:26 AM 1) Electric Passenger Window doesn't move up and down properly. It's a common problem on E36's . . Does it go up an inch at a time? If so . . you have to buy a new motor. I have the same problem. 2) Mileage display (digital) doesn't light properly so I can see the total mileage but not the trip mileage. This may help to get inside of the Instument Cluster and you may have to replace some LED's . . . http://www.logun.org/gauges.htm 3) Water drips in when I have the driver sidfe window open. I have the same problem . . . don't roll down your window. 4) Air con doesn't seem to work. Could be a number of problems . . . Does it turn on? If so you could need a recharge or need a new condensenor or a new A/C Compressor? Good Luck ! ! Automotive Network, Inc., Copyright ©2012
