Do i really need the wiring harness?mellowboy 03-28-2002, 01:22 PM This is how much i paid for my swap...motor/trans/ecu for 1087.50 after taxes!(thought u guys might wanna know) IT seems like it came with the whole wiring harness?? How can you really tell if its the whole harness or not? So do i need to buy the HaSport ones or just use the wiring on my crx si? Thanks 4GZChatch 03-28-2002, 02:14 PM What motor did you get? If it's a ZC, the Si wiring harness will hook right up, if its a B16, you probably need to get an HASport so that it is complete. (I think, but I don't have a B16 personally, so you may want to verify that.) I do have a ZC, and my stock harness worked fine. Happy swapping! :) mellowboy 03-28-2002, 02:35 PM Originally posted by 4GZChatch What motor did you get? If it's a ZC, the Si wiring harness will hook right up, if its a B16, you probably need to get an HASport so that it is complete. (I think, but I don't have a B16 personally, so you may want to verify that.) I do have a ZC, and my stock harness worked fine. Happy swapping! :) Read my profile man!!:D I have a b16. I was askin this because it seems like all the plugs match my rex plugs. I hope its all plug in shit! Yeh i do hope the swap goes good. Its my first time and so is my other friend who graduated from UTI..i hope he's a good help. EightOhOne 03-28-2002, 07:17 PM Just use your si harness man. Use the b16a harness for spare plugs for the 4 wires you need to run for the b16 cspu 03-29-2002, 01:59 PM Originally posted by EightOhOne Just use your si harness man. Use the b16a harness for spare plugs for the 4 wires you need to run for the b16 There are only 4 wires extra for the B16 in a 4th gen Si? shatshadarach 03-29-2002, 10:55 PM ya...just use your si harness...make sure you label it all so you dont f up...but my buddy and i did his wiring today in like an hour...real easy... mellowboy 03-29-2002, 11:21 PM Originally posted by shatshadarach ya...just use your si harness...make sure you label it all so you dont f up...but my buddy and i did his wiring today in like an hour...real easy... Yeh i just found out that they gave me the whole wiring harness!! Its just plug ins now. I think i just have to rewire the v-tec pressure thing? Shit i don't know lol. I have the J1 tranny and the speed sensor seems like its been cut? It has the long black stiff wire ( i think its a wire) that looks like it has been cut? I looked at my friends Y1 tranny and its totally different from what i see ? Can you help me on that part? shatshadarach 03-31-2002, 11:59 PM im just picturing mine in my head, the long black wire, clutch cable?? they usually cut those and leave em on the motor.... mellowboy 04-01-2002, 10:17 AM Originally posted by shatshadarach im just picturing mine in my head, the long black wire, clutch cable?? they usually cut those and leave em on the motor.... No its the speed sensor. They cut the wire on it. Is it possible for me to rewire it . Please help. Thanks. 91zc 04-01-2002, 08:39 PM There should be a black boot covering the bottom part of the speed sensor that is still in the trans. Under it should be a clip holding the sensor into the trans. Take the clip out and pull the old sensor out. Then once the motor and trans are in the car plug in your stock speed sensor and secure it with the clip. HTH mellowboy 04-02-2002, 10:17 AM Originally posted by 91zc There should be a black boot covering the bottom part of the speed sensor that is still in the trans. Under it should be a clip holding the sensor into the trans. Take the clip out and pull the old sensor out. Then once the motor and trans are in the car plug in your stock speed sensor and secure it with the clip. HTH The stock sensor from the d16a6 or the b16? The only black boot on the sensor is located on the top where the wires come out of it? 91zc 04-02-2002, 03:29 PM Yeah, there should be a clip holding the sensor into the b16 trans. Take it out and then plug in your stock sensor and use the clip to secure it. rosman4u 04-04-2002, 03:14 PM hmm..interesting info Automotive Network, Inc., Copyright ©2012
