Power Steering and A/C after SR Install
240Will
03-20-2005, 12:16 PM
Does anyone know how to retain the use of power steering and a/c after installing SR into late-model 240?
R.W.240
03-20-2005, 05:21 PM
SR Powersteering is bolt on
SR AC is bolt on but the wiring is a bitch
sidewayzS13
03-20-2005, 06:14 PM
who needs it?
240Will
03-21-2005, 12:16 PM
So i just need to find a SR powersteering pump and a/c compressor and lines and it should work once i wire the a/c?
nissan180
03-21-2005, 12:24 PM
correct
R.W.240
03-21-2005, 04:07 PM
KA AC Compressor is bolt on (3/4) if you cant get an SR one
240Will
03-21-2005, 06:44 PM
Well if the KA compressor is basically bolt-on, then why do so many not retain a/c after installing the SR? Is it a space issue or more an issue of doing the work? How much modification is reguired to do this, and are there any tutorials online concerning this?
AWDSR20
03-21-2005, 07:23 PM
dude, the DOHC KA power steering unit is a BOLT on to the SR one... ??? whats the prblm?!
Manji_240sx
03-22-2005, 05:35 PM
ya the ka powersteering will work and the ac comp. i have an sr comp. if needed
LaYzIeNoY
03-23-2005, 01:33 AM
DOHC KA p/s pump works perfect
the a/c is lost becuase a bunch of people don't care much about the a/c, the work for a SOHC compressor is harder you have to make a special bracket and the lines for SOHC and DOHC are different so to get them to work requires modification that people don't want to do
R.W.240
03-23-2005, 09:27 AM
it weighs 50+Lbs?
