Originally Posted by public
No spark on start up is either the Crank Sensor or the Ignition Module. Both coils going bad at the same time is very unlikely. Many parts stores can test your module for you. The Crank Sensor is only about $20 but cannot be tested. Good Luck.
Thank-you for atttempting to help me I will attempt to check ignition module at local auto store I just think that I am a dumb lady when I ask them I also will purchase a crank sensor. Just in case both are bad. Thank-you for your response I will submit a query if niether of the two I do appreciate the help very much
