Still Having Starter Problems!silverstalker 03-18-2005, 09:52 AM I had posted a previous thread about my 1986 Ford F150 starting problems and I have done everything I know to do,I have checked the timing,checked the battery,replaced the starter(the one I put on a few days ago broke,thats the 2 starter to break in a month)I tried a shim on the starter,changed solenoid,put new flywheel on,nothing seems to work!The engine tries to kick backwards when starting thus binding the starter and breaking the mounting brackets.PLEASE HELP!! mustangmike351c 03-18-2005, 06:38 PM what about your plug wires? There is a chance you could have one crossed up and it would run ok. check 7 & 8 also make sure 7 & 8 are not running together because #8 fires 100deg before #7 gets to tdc so when the magnetic field collapses on #8 it fires #7 100deg btdc Automotive Network, Inc., Copyright ©2012
