Originally Posted by richtazz
Going to the simplest things first, did you check the fuses? The next thing I would check is your fuesable links. Most circuits that have power with the key off are protected by a short piece of aluminum wire that is designed to burn out first in the event of a circuit overload. IF you live in a state that uses salt on the roads in the winter, this aluminum wire can corrode and get brittle, break and cause a circuit malfunction. Most cars have fuesable links mounted at the starter to the post that the Battery cable hooks to.
I checked the fuses and they were fine, I also checked the ckt brkr in the glove box fuse panel and it happened to be burned out. I replaced the ckt brkr and the lights still don't work.
It wasn't the parking brake switch. I used a multimeter and checked voltage; pbrake engaged - no flow, pbrake disengaged ~ 12.
I spoke with another dealer today and he brought up the possibly of a bad F-Connector. I'm trying to find this part but can't on gmpartsdirect.com. Called three dealerships (all the connectors and switches i've dealt with on this issue have been dealer parts) and none of them stock it but could have it in a day or two.
Don't think the salt will be an issue, I live in Georgia
The problem is still intermitent. Every now-and-then the lights decide to work.
the other parts i'm looing at are the Daytime Running Lamp Control Module. I was thinking it could be causing this because sometimes, (with the headlight switch on) when I would open and close the door hard, the lights would pop on.
I'm still working on it, i'll look into the fusible links and post back later
Thanks.
