Engine Coolant Leak?
case2k5
03-17-2005, 12:16 PM
The engine coolant will leak out on the bottom of my expedition when I turn the car off. It has overheated once in the red and engine was about to stall when I discovered the problem. What is the best way to check what this would be?
Thanks for your help
way2old
03-17-2005, 06:15 PM
You can get under it and see where the leak is starting from. If you can get a pressure tester and have the system pressure tested, the leak will show quickly.
