stalls when idlechirsg01 03-17-2005, 09:35 AM need help. i have a 97 f-250 powerstroke 7.3 diesel. just recently, it started to stall when i idle in traffic or make a slow turn (less than 5 mph). it only happens maybe once a day or every few days. any suggestions would be appreciated!! adamwood78 05-06-2005, 03:01 PM Did you ever find out what the problem was? I have an 01 7.3 and will die occasionally when I am idleing. It will also miss every once in a whilie when I am on the highway. need help. i have a 97 f-250 powerstroke 7.3 diesel. just recently, it started to stall when i idle in traffic or make a slow turn (less than 5 mph). it only happens maybe once a day or every few days. any suggestions would be appreciated!! l-m tech 05-07-2005, 01:19 PM Did you ever find out what the problem was? I have an 01 7.3 and will die occasionally when I am idleing. It will also miss every once in a whilie when I am on the highway. camshaft position sensor will cause this problem. baul1 05-17-2005, 05:16 PM could be your catalitic converter stopped up i have a 87 ford 300 inline 6 and i replaced all my sensors and egr valve idle air valve etc it was the converter hope that helps later man chirsg01 06-23-2005, 12:36 PM changed the Camshaft Position Sensor and its all good. Real easy fix. Took about 5 minutes to change out. Automotive Network, Inc., Copyright ©2012
