Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 03-16-2005, 06:14 PM   #1
lionelkirk2004
lionelkirk2004 Normal reputation
Send a message via Yahoo to lionelkirk2004
Tune-Up Question?
I was just wondering if someone knew whether or not i needed new Spark Plugs.
It's a 1996 Pontiac Grand AM 2.4L. It has 132,000 miles on it.
Now, As far as I know, the car hasn't had a tune-up with me yet. I got the car with about 103,000 miles on it. I haven't had a tune-up yet but I am wondering what are some of the symptoms of needed a tune- up or getting new spark plugs.
The car hesitates sometimes but not alot and it drives pretty nice for the year and the miles on it.
Any Idea of some symtoms or what needs to be done?
lionelkirk2004 is offline   Reply With Quote
Old 03-16-2005, 06:28 PM   #2
GTP Dad
Pontiac Guy
GTP Dad Normal reputation
Re: Tune-Up Question?
Yes you need a tune up! New plugs will help both performance and fuel economy. With the 2.4 you may want to check the coil assembly under the cover between the cams for carbon tracking. (Black or Grey streaks) if you notice them you may want to replace the coil assembly. You have to remove this to get to the plugs anyway.
GTP Dad is offline   Reply With Quote
Old 03-16-2005, 06:29 PM   #3
lionelkirk2004
cool, thanks. And do you know exactly what tools I need? I have a repair manual. But I just need to know what tools to use and stuff.
Old 03-16-2005, 07:42 PM   #4
Hoags
Hoags's Avatar
Hoags Normal reputation
The cover bolts are 15mm and the screws to get to the coil assembly are 1/4inch or 7mm I can't quite remember. I'm not sure of the size needed for the plugs but I used my smaller size plug socket it has a rubber insert so yoou don't damage the creamic part of the plug. When you take the cover off I have found it much easier to work with if you disconnect the wire harnes on the right hand side of the cover.
It's not a difficult job, you can do it in less than 1/2 hour.
Hoags is offline   Reply With Quote
Old 03-17-2005, 03:23 AM   #5
Knifeblade_03
Knifeblade_03's Avatar
Knifeblade_03 Normal reputation
Send a message via Yahoo to Knifeblade_03
Spray the plug wells out before pulling them!!!!!!! Get all the rust/dirt/etc. out of the wells first. Use compressed air can, the type we use to blast our keyboards with.
Then, spray some penetrate lube into each plugwell, let it work an hour or so, makes the pull easier, and nothing [if ya airblast the wells out first] will drop into the cylinders.
Knifeblade_03 is offline   Reply With Quote
Old 03-17-2005, 06:24 AM   #6
Hoags
Hoags's Avatar
Good point Knifeblade!
Bookmarks
Google
Web AF
