anti-lock trouble?afcop7111 03-15-2005, 07:18 PM OK, have my 97 z24 with 174k on it and today returning from a trip the anti lock brake light came on. I pulled over and turned the ign off waited a moment, started it back up and it reset. Started on down the road and heard a click, like a relay, or switch and it came back on. After trying this a few times with little or no luck, I resigned to the fact that something is busted. Normally when you turn the ign on that relay for the anti lock cycles through like making a series of short clicks real fast and the system is set. Mine will now only make about a short click and nothing else. Dealer said no safety problems and it should have put a code in the computer. Should I look into this?, or can you disconnect the whole works which would make the light in the dash go off. Bugs you at night being bright orange. Thanks in advance. noshun 03-15-2005, 09:44 PM OK, have my 97 z24 with 174k on it and today returning from a trip the anti lock brake light came on. I pulled over and turned the ign off waited a moment, started it back up and it reset. Started on down the road and heard a click, like a relay, or switch and it came back on. After trying this a few times with little or no luck, I resigned to the fact that something is busted. Normally when you turn the ign on that relay for the anti lock cycles through like making a series of short clicks real fast and the system is set. Mine will now only make about a short click and nothing else. Dealer said no safety problems and it should have put a code in the computer. Should I look into this?, or can you disconnect the whole works which would make the light in the dash go off. Bugs you at night being bright orange. Thanks in advance. check the ABS sensors. they may have a bad connection or may by soiled. afcop7111 03-18-2005, 04:52 PM check the ABS sensors. they may have a bad connection or may by soiled. Thanks, that is what it was! noshun 03-19-2005, 12:16 AM Thanks, that is what it was! no problemo! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
