to BLAZER ltbigry2004 03-14-2005, 12:48 AM Hey BlazerLT, just curious. what work has been done to your vehicle mechanically ?besides all the sweet customizing and upgrading [i checked out your site] just wonderin how yours has been and what stuff you have had to done say during the past 50k. BlazerLT 03-14-2005, 01:47 PM Hey BlazerLT, just curious. what work has been done to your vehicle mechanically ?besides all the sweet customizing and upgrading [i checked out your site] just wonderin how yours has been and what stuff you have had to done say during the past 50k. In the past 50k? Hmmm..... Ok, mostly normal maintanence but I have had to replace some big things like the flywheel that had 5 teeth taken off because of a bad starter and bad starter installation by my father 6 years ago. Then the alternator blew which again, was purchased at the same time and the same rebuild place as the shitty starter. Other than that, a new fuel pump, sending unit and tank was installed (Thank Canadian weather for that one.) Small things replaced: - CPI injector - nut kit - plugs - cap & rotor - front sway bar bushings and endlinks. - front and rear shocks - three of the four ball joints. - rear u-joint - Transmission and transfer cases and differential case (2) flush and fill. Most of the repairs have been normal maintanence other than the tank and the flywheel. Truck has 131k on it now. Automotive Network, Inc., Copyright ©2012
