how can I increase power
Rick's69
03-13-2005, 03:34 PM
I have an 1835cc engine and i was wondering how i can make it faster, i have the stock 34 solex carb. will a bigger carb add HP? any ideas?
jermphil
03-13-2005, 10:15 PM
dual carbs..i tink your large enough in the bores..i asked a friend about htis and he said a dual carb setup would help a lot, and probably a larger exhaust system.
Rick's69
03-14-2005, 10:09 PM
thanx thats pretty expensive tho. ill check ebay.
scottw68
03-16-2005, 10:53 PM
I'm going to post a 2 barrel holly weber progressive on E-Bay in a few weeks I'll let you know when I do. It comes with dual port intakes, manifold, and a chrome air filter. Its used and will probably need a rebuild but i will be a lot cheaper than new.
trooperbrett
03-17-2005, 06:25 PM
I have a 1776 and I'm running two dual throat Weber 36 IDF's, with big valve heads and 1 1/2 inch exhaust and it runs pretty good. I picked up the Webers on Ebay for $300. You can use dual single thoats too, like Kadrons or the dual Solexes with chokes from CB Performance. With your displacement you can use more carberation along with a good exhaust.
Brett
Rick's69
03-17-2005, 09:06 PM
alright thanx
