This is going to be a long lost so you don't blow up your engine.
36lbs injectors minimum
Walbro 255 fuel pump
FPR
Intercooler
All the tubing
High Volume Oil Pump
Oil Cooler
Low Boost Wastegate
With these things you shouldn't blow your engine. You need the upgraded fuel stuff to make sure you don't go lean and fry your car. The intercooler is so you don't detonate, the neon has like a 9.3:1 compression which is extremely high for a turbo, I think the SRT has like 7.8:1 or 8.2:1 or something like that. The oil pump will be able to supply the higher volume of oil you'll require due to te added heat of the turbo, the oil cooler is to try and keep your engine temp down as much as possible. The wastegate is self expanatory I WOULD NOT go over 8psi on stock internals. Also if you have a Mopar computer, I would change it out for stock unless you have adjustable cam pulley, and can back down your timing manually, they advance your timing greatly and will increase the chance of detonation.
