94 ZJ Limited 5.2L PCM NEEDED!
dksob81
03-12-2005, 02:02 PM
Anyone have a or know of a PCM for a 94 Jeep Grand Cherokee Limited 5.2L V8. I need one, CHEAP. (cheapest I found was Advance Auto Parts - $279 need one way cheaper then that. around $100 +/-
ekmarsal
03-12-2005, 03:24 PM
I always say check on ebay first and then you got AutoZone, PepBoys, Napa...there's got to be somewhere cheaper then that. Good luck.
Cam7
03-14-2005, 05:09 AM
Check E-Bay Got mine for $35 for my 5.2
dksob81
03-14-2005, 10:24 AM
well after searching ebay for an hour and came up with nothing. I didn't need a new PCM afterwards. I found my problem - bad wire grouding out, causing PIN #7 to shutdown the voltage - cut the wire got voltage back as soon as I hooked wire back up lost vltage, then searching through the wiring schematics and seen this wire supplies voltage to the CPS checked cps for bad ground and that was my problem - apparently the CPS wiring must touched the Exhaust manifold or engine block and melted the housing causing it to ground out.
