Need Info On The 16 Pin Data Link Connectordlf35121 03-12-2005, 01:10 PM i have a 95 blazer that want responed to a code reader or a scanner. i was checking the DLC and mine has a pin in #2,4,5,9,13,16 in the haynes manual they show one that has the pin in 4,5,6,9,13,16. the date on my is 9/94 if anyone has the earley 95 and knows if my pin are in the correct place please let me no thanks in advance ricksza 03-12-2005, 05:48 PM Here's what the 1995 Shop Manual Says: Pin 2 = Serial Data Signal 4 = Ground 5 = Ground 9 = Serial Data Signal 12 = Electronic Brake Control Module & Vehicle Speed Sensor Buffer 13 = Transfer Case NP1 only 16 = Battery Feed BlazerLT 03-13-2005, 12:12 AM You will need an OBDII scanner. Automotive Network, Inc., Copyright ©2012
