96 F150 dies when fuel tanks are switchedMage218 03-12-2005, 11:47 AM I have a 96 ford f150 manual with 2 fuel tanks and everytime i flip the switch to switch from the front tank to the rear tank the truck dies, anyone have any suggestion on what could cause this? Thanks n advance. FORDTRACMAN 03-12-2005, 07:36 PM I would first check to see if you have power to the rear when switched.If yes,then i would guess you have a fuel delivery module malfunction. Mage218 03-13-2005, 12:32 PM Would a fuel delivery module malfunction cause the check engine light to come on?? andy2005 03-13-2005, 06:06 PM The exact same thing happens in my '92 F-250, I was told it is the switch on the dashboard gone bad. Ridenour 03-13-2005, 09:04 PM Is there a fuel pump per each tank? If so, maybe the pump in the other tank is dead, so when it switches over to that one, it just can't pump, thus dying. FORDTRACMAN 03-14-2005, 08:15 AM First-You need a manual.Next you need to check for power to the [FDM] fuel delivery module[fuel pump-sender check valve and associated parts [FDM].Yes you have 2 [FDM] pumps.One in each tank. Lostandconfused 12-23-2006, 01:12 PM Hi ya Mage218, did you ever pinpoint the problem? My 96 auto, straight 6 dual tanks, does the same thing. :banghead: THANKS! Mage218 04-01-2007, 04:10 PM sorry didnt check the post till now but no we never figured it out i assume it was the fuel pump but it got traded in for an 07 dodge ram lonestar edition on 20s Cait Sith Cat 04-02-2007, 09:27 AM That happened to me for one day a few weks ago. I would switch to the front tank, hear a hissing sound, and the truck would die. bawest 11-11-2007, 09:07 AM Hi my 95 did the same thing. the gauge would switch, but the truck would die. I replaced the fuel pump, and all is well now. Had to remove the bed, but the job wasn't too hard. the toughest part was the bed bolts spinning, but I tack welded the heads, and it went great. Automotive Network, Inc., Copyright ©2012
