steering slop
thehawksters4
03-12-2005, 07:38 AM
Just bought a 98 blazer with 117,000 miles. Noticed that there was some slop in the steering and that it had a tendency to drift back and forth across the road. I have replaced all the ball joints and the pitman arm. The front end is really tight now but I still have some of the slop. I have nailed it down to the steering gear box. With the wheels on the ground you can move the steering wheel in each direction about a 1/2 "before the tires move. There appears to be an adjustment nut of sorts sticking out of the top of the gear box. Is this something I can adjust to take slop out and if so how do you adjust it?
rlith
03-12-2005, 09:47 AM
See my post at the top of the forum (Facts about steering slop) It's more likely the rag joint on your intermediate shaft.
ricksza
03-12-2005, 05:54 PM
Did you have the front end aligned since the front end work was done? Toe adjustment can cause wander.
