Re: Tune Up?
A complete tune-up should be done every 3 years or 50,000 miles, this includes plugs, wires, cap, rotor.
Fuel filter and pcv valve every two years.
Air filter, depending on conditions, should be changed every 6 months.
Cooling system should be flushed and new rad cap installed every three years.
Full lube every oil change, this includes:
greasing the front end (upper and lower ball joints, inner and outer tie rod ends, idler arm, and pitman arm...11 fittings total )
oiling the door and hood hinges
graphite in the key cylinders
Check the brakes, hoses, belt, and wiper blades regularly and replace when needed.
More detail about brakes:
Depending on your driving style and the quality of the brakes they will 6 months - 6 years.... you can't put a set time or mileage on brakes they need to be checked and replaced when needed. To check:
look and make sure you have at least 1/8 inch of pad left. (brakes have "squealers" that will let you know when excessively worn)
check the rotor for signs of damage...grooves, scratches and burnt marks.
