Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Saturn > SC/SL/SW
Old 03-11-2005, 12:41 PM   #1
fundiablo
fundiablo Normal reputation
Oil weight, Valve cover change...
I recently bought my ex's 97 SC2. It has 76,000 miles. She almost ran it into the ground. During a minor flood, it got water in the interior, not in the engine though. I changed out the carpet and cleaned out the interior. I just changed the valve cover gasket yesterday cause the 1 & 2 plugs were swimming. I used the info from here to help. The car would start, run ok, maybe idle a little high, but then wouldn't turn over again for couple of hours.
Question 1: How long do I have to wait before I can drive the car? I used a Fel-Pro rubber Gasket and thin layers of Permatex blue RTV. The RTV info said it fully cured in 24 hrs. Do I have to wait that long?
Question 2: When I got the car it had almost no oil. (And was leaking from the valve cover) I, without checking like an idiot, used 10w30. Yesterday, I noticed the oil cap was cracked and that It said to use 5w30. Other than changing the oil, filter,and cap, do I need to do anything else at this point? I've changed the PCV valve and will change the plugs and wires this weekend. The car does just need a alot of TLC. I thank you in advance for the input.
fundiablo is offline   Reply With Quote
Old 03-11-2005, 05:54 PM   #2
sickcallawayc12
sickcallawayc12's Avatar
sickcallawayc12 Normal reputation
1. I heard some RTV companies actually recommend that you drive the car after applied but not all do. Also, i think you need to disconnect your battery again for 15 seconds or so and reconnect to reset the computer. When you remove the pcv valve from the cover, the computer won't let the car start when reconnected again for a safety measure. I had this problem when i changed my gasket a few months ago and thought it was the battery but sierrap15 said this as one of the options (cant remember if this is EXACTLY was he said, but i know it is something along those lines).
2. I have used 10-w30 ever since i bought mine. Most people use 10w30 in the winter i believe for their saturns but i don't know that much about oil. It's good there wasn't a lot left since it isn't good to mix oil types. the pcv valve you changed should have been a saturn part; people will tell you long stories of problems with the replacements from autozone and such. get ngk plugs too.
sickcallawayc12 is offline   Reply With Quote
Old 03-13-2005, 03:27 PM   #3
sierrap615
Master Tech Wanna-be
sierrap615 Normal reputation
Re: Oil weight, Valve cover change...
5W-30 for winter, 10W-30 for summer. get both the PCV valve and oil cap from a saturn dealership. do not but the Saturn brand oil filter (its a FRAM, FRAMs don't clean worth crap)
the high idle maybe -
1.ECT
2.sticking EGR
3.sticking IAC
no start when warm maybe
1. CPS(they then to fail when warm first, you would have no spark)
2. the common 97 fuel pump problem(see below)
3. one of the above three(unlikey)
the 97 fuel pump had a problem with retaining pressure after shut-down, search saturnfans.com for more info.
as for reseting the computer, the computer "learns" the condisions of the motor(aka, fuel flow, spark power, sensor range, poor airflow, ect) and acts accordingly, its called adaptive stradigy(SP?). if you perfrom any major work, it may affect what the computer expects to see, and therefor, runs poorly after the repair, until the computer learns the changes. some times, this will even cause a no start after the repair. reseting the computer speeds up the relearning process. although, i really don't see how changing a valve cover can effect the computer that much, it did happen to me last summer.
also contine to watch the rate of oil loss and please report back!
sierrap615 is offline   Reply With Quote
Old 03-14-2005, 03:12 PM   #4
fundiablo
Thanks for the info guys. I did wait more than 24 hrs to run it. It started up fine, idled better, but I think still slightly high. After the test drive though, it wouldn't turn over again. It cranks, but I have mash the gas pedal down to get it almost turn, but it doesnt't, like it's not getting enough fuel, but then it smells like gas. I'll check the suggested stuff, especially the fuel pump. Oh, and i also have to redo the gasket. It leaked on the side by the EGR. When I put the gasket on the valve cover the first time, there seemed to be a tiny amount of slack. Is that normal?
Old 03-30-2005, 04:26 PM   #5
fundiablo
97 sc2
Replaced the ECTS, that fixed the hot start problem I was having. Now the car is running warm. Just replaced the thermostat. I got tiny droplets of antifreeze being kicked of the serpentine belt. New thermo isn't leaking and hoses seem fine. I think it may be the waterpump. How hard is it ti get to and change?
Old 03-31-2005, 01:37 AM   #6
sierrap615
its in a pretty tight spot, forget torque specs unless you have some crowfoot sockets.
http://www.saturnfans.com/forums/showthread.php?t=24144
Old 03-31-2005, 02:08 PM   #7
phattyc75
phattyc75 Normal reputation
Torque specs? Who uses torque specs these days? HAHA....
(jk)
phattyc75 is offline   Reply With Quote
Old 03-31-2005, 05:51 PM   #8
peppermrj
peppermrj's Avatar
peppermrj Normal reputation
Re: Re: Oil weight, Valve cover change...
(jk)
1/4 inch bolt=1 finger and 1 thumb on ratchet (1/4 inch drive)
5/16 inch bolt=2 fingers and 1 thumb on ratchet (1/4 inch drive)
3/8 inch bolt=2 fingers and 1 thumb on ratchet (3/8 inch drive)
7/16 inch bolt=3 fingers and 1 thumb on ratchet (3/8 inch drive)
1/2 inch bolt=4 fingers and 1 thumb on ratchet (3/8 inch drive)
Sorry no metric conversion available at this time
peppermrj is offline   Reply With Quote
Bookmarks
Google
Web AF
